B16a2 evap solenoid removal problem
Old Apr 11, 2014 | 11:13 AM
GT500FTW's Avatar
Default B16a2 evap solenoid removal problem
Hey guys
I have a civic with a B16A2 obd1.
I have removed the EVAP purge solenoid (i know there are many different types - mines mounts onto the back right corner of the I'M)
I removed it because i have an alloy fuel tank in the trunk with non standard fuel lines and it purges any unwanted fuel vapours to the atmosphere.
My problem is:
I removed the evap solenoid and the engine runs fine with no cel or anything, but it has a terrible hissing noise from the hole at the back of the I.M. where the solenoid used to be.
When i block the hole, the engine idle lowers to about 500rpm and it stalls.
Is this normal?
Should i just ignore the hissing noise?
Old Apr 11, 2014 | 11:35 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B16a2 evap solenoid removal problem
You need to block the hole, then do the idle reset procedure.
Old Apr 11, 2014 | 12:07 PM
GT500FTW's Avatar
I've searched and found a couple of different reset procedures - Do you recommend i just adjust it with the idle adjustment screw?
Old Apr 20, 2014 | 01:51 AM
GT500FTW's Avatar
Do I still leave the solenoid plugged in. Or do I just throw it away and tie up the connector?
Old Apr 20, 2014 | 05:13 AM
HondaPartsHero's Avatar
Technical Hero
Old Apr 20, 2014 | 03:18 PM
GT500FTW's Avatar
Thanks very much. I have adjusted the idle now.
Should I leave the evap sensor plugged in or should I disconnect it?
kona_4door
Sep 14, 2010 05:11 AM
ben1284
Feb 18, 2008 06:17 PM
b16brandon
Dec 7, 2005 01:22 PM
RABBIT9
Jun 24, 2003 08:54 AM
