Whts the best swap i can do????????????
Old Oct 29, 2002 | 08:24 PM
1997exciv12w3's Avatar
Default Whts the best swap i can do????????????
I have a 97 civic ex.....whats the best swap i can do for power???
Old Oct 29, 2002 | 08:31 PM
clm_Sol's Avatar
Default Re: Whts the best swap i can do???????????? (1997exciv12w3)
2jz
Old Oct 29, 2002 | 08:34 PM
NrG's Avatar
NrG
Default Re: Whts the best swap i can do???????????? (clm_Sol)
rb26dett
IM ALL BOB's Avatar
Search Button is your friend
Old Oct 29, 2002 | 08:58 PM
MugenCivic's Avatar
Default Re: Whts the best swap i can do???????????? (IM ALL BOB)
either a B16b or a B18c good luck
Old Oct 29, 2002 | 09:30 PM
flip b18b's Avatar
Default Re: Whts the best swap i can do???????????? (MugenCivic)
b20/vtec? h22a? ls/vtec b18c it all depends what you wana do for build up / useage
Old Oct 29, 2002 | 09:47 PM
mycivicstoo(s)low's Avatar
Default Re: Whts the best swap i can do???????????? (VTEC VX)
Briggs & Stratton
Old Oct 29, 2002 | 10:03 PM
Tofurky's Avatar
ramJet 502
Old Oct 29, 2002 | 10:09 PM
SpoonSportsJunkie's Avatar
Default Re: Whts the best swap i can do???????????? (Ruckus138)
A Chevy "tree fity"
No seriously. If N/A is your goal, Pound for pound Itr motor w/ tranny is awesome way to go.. second choice Gsr built w/ Itr parts and skunk two manifold,
3rd choice is ctr, 4th is b16a built, 5th is integra non vtec.
H22 if you only want to go straightline fast and don't care for handling.
If turbo, Ls integra built w/ drag kit.
or b20 crv w/ drag kit.
Oh don't forget the ghetto rims for "bling bling " factor.
Old Oct 29, 2002 | 10:58 PM
chillly's Avatar
A Ford JDM Mazda KLZE turboed with 10psi of boost & stock fuel system.
With this setup you will ow3n at the ice races......
Old Oct 29, 2002 | 11:00 PM
poison's Avatar
Default Re: Whts the best swap i can do???????????? (uncivilCivicinprogress)
big block 400 bored 20 over
Old Oct 29, 2002 | 11:06 PM
94hondaLS's Avatar
h22a best swap in my opinion. has lots of torque, reliable stock power(w/out mods). no doubt you'll run with v8's. only thing to worry about is broken axles i suggest place racing they make strong ones.
[Modified by 94hondaLS, 8:08 AM 10/30/2002]
Old Oct 29, 2002 | 11:10 PM
Bleed Black's Avatar
Default Re: Whts the best swap i can do???????????? (94hondaLS)
Cheese....a ignorant reply for a ignorant question
Old Oct 30, 2002 | 12:59 PM
ZetecOwns's Avatar
hahahahahahah.... i remember that, that guy was hilarious!
Old Oct 30, 2002 | 01:06 PM
phillycx's Avatar
Default Re: Whts the best swap i can do???????????? (sohcvtecrx)
I always restrain from making a smart comment, but you PROBABLY should use the search function offered by this forum. Good luck!
WE DO HEAR THIS QUESTION TOO OFTEN ...IS THERE A WAY THAT WE CAN REQUIRE PEOPLE TO SEARCH FIRST!?
Old Oct 30, 2002 | 01:12 PM
SuperRice's Avatar
Welcome to honda-tech. You should be aware of one thing, people here are intolerable to repeatitive question. If you ask a dumb question, expect a dumb answer. Oh yeah, learn to use the search function before you ask anything next time, the chances are it has probably been asked numerous times before. So it's best to do some re-search before you post, otherwise you're gonna get answers like in this thread. Good luck!
[Modified by SuperRice, 10:14 PM 10/30/2002]
Old Oct 30, 2002 | 01:29 PM
B_CRUZ!'s Avatar
Default IB4TL...........
[Modified by B_Cruz, 2:29 PM 10/30/2002]
Old Oct 30, 2002 | 02:34 PM
Aggreed that is a strong motor...But makes the car wayy too front heavy leans forward towards front bumper as uposed to b series sitting a lil more upright. ...Preyludeswap= sucky handling !!!
++++ super important. that you know the preylude block has Horrible cylinder walls!!! the metal is a crappy material compared to the quality of a b series vtec block . Preylude H22a cylinders have a special coating that prohibits from being able to safely bore it over if you need to ...so you'd have to resleeve it ! This is what I hear from a reputable Machine shop mechanic and my honda (raceminded) Oem Mechanic (certified w/ honda since 84')
So beware... Building a b20 Vtec is a more viable option... Sleeving it w/ bigger bore w/ Itr head= nicey nice! Remember H22a swaps give a crap load of wheelspin..there is only so much torque you can actually use in a ffwd car.
Old Oct 30, 2002 | 02:40 PM
B_CRUZ!'s Avatar
Default Re: Whts the best swap i can do???????????? (SpoonFanatic)
do you have info to back this up? so basically you have driven a H22 powered hatch on a road course...
integraNooB
Apr 14, 2008 05:26 PM
swapcivic97
Apr 10, 2006 07:30 PM
Luchini
Nov 3, 2003 04:50 PM
allmotorls95
Oct 24, 2002 11:13 AM
allmotorls95
Oct 21, 2002 06:26 PM
