d15b 3 stage info & help pt2
Old Apr 10, 2014 | 06:45 PM
lerks909's Avatar
Default d15b 3 stage info & help pt2
Need help on figuring out to get this engine working right don't have money to take it to the shop And spending more money then what it is worth. I need to know what ecu to run p08 or a p28? What intake mani the one it came with or the one i have is a d15b7? Im using a obd1 harness with a non vtec dizzy with wires ...ps i have a usdm auto tranny cant afford to swap to 5spd
Old Apr 10, 2014 | 11:12 PM
raverx3m's Avatar
Default Re: d15b 3 stage info & help pt2
didnt you already figure it out in the other thread?
Old Apr 11, 2014 | 04:25 AM
lerks909's Avatar
No it idles real bad idk what it is
Old Apr 13, 2014 | 10:52 PM
raverx3m's Avatar
didnt you say the headgasket was blown?
Old Apr 14, 2014 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
Neither of those ECU's are for that engine. Is your check engine light on? What codes?
Old Apr 14, 2014 | 04:12 AM
lerks909's Avatar
I received another obd2 cause they didn't have a obd1 in stock ....I fixed the idling problem now my transmission won't shift at all
Old Apr 14, 2014 | 11:52 AM
Technical Hero
What ecu are you using? Is it auto?
Old Apr 14, 2014 | 12:27 PM
raverx3m's Avatar
Just trade it for a z6 motor bro and stop messing with .
Its been like 3 weeks now? You will have a running engine by now if you just keep it simple
Being cheap costs you in wasted time unless your time is not worth anything
Old Apr 14, 2014 | 03:15 PM
lerks909's Avatar
Yes its a auto m24a tranny ..I'm using a p06 ecu
Old Apr 14, 2014 | 03:17 PM
lerks909's Avatar
Yupp 3 weeks with this stupid a** engine nobody wants to buy this engine Or trade its a head ache had it on craigs already
Old Apr 14, 2014 | 07:48 PM
raverx3m's Avatar
damn well if you were here i would go pull one from pick and pull and rebuild it for you lol
where you live at?
Old Apr 14, 2014 | 08:33 PM
lerks909's Avatar
This engine is all bad bro..I live in california I talked to some guy that was going to buy a eg8 with this engine and the owner was using usdm 4 speed tranny and it was working perfect...the thing is he didnt see or ask wat ecu he was using and the 2 solenoids on the tranny wasent hooked up
Old Apr 22, 2014 | 06:30 PM
lerks909's Avatar
Got my tranny shifting and my engine running right ...I'm using a non vtec ecu feels like a I'm towing a car and I think I'm running rich? By me chipping my ecu will cause these things to go away? Ima chip it to a p08
lerks909's Avatar
Bumpppp***
Old Apr 22, 2014 | 07:06 PM
raverx3m's Avatar
you need to read the links that were posted.
theres no magic answer that someone can give you to make your car run right.
no matter how many times you ask.
download crome free and compare all the different single cam fuel and ignition maps maybe you will understand how much difference there is
which can be found on pgmfi wiki.
also register on pgmfi and browse through the forum theres tons of info there
Old Apr 23, 2014 | 06:18 AM
lerks909's Avatar
Thanks ima look it up..I don't know anything about ecu's aha
Old Apr 23, 2014 | 04:26 PM
grumblemarc's Avatar
The Grumpiest
The ECU you need is a P2J for that engine. Don't know if there's a version for an auto.
Old Apr 23, 2014 | 05:21 PM
nub's Avatar
nub
There's an auto P2J but it's for the CVT so it won' work.
It's been said before...this engine in an OBD1 car in California is a big mistake.
Old Apr 23, 2014 | 06:41 PM
lerks909's Avatar
Well I heard a p08 will run the fuel maps but not the 3 stages of this engine...really don't care about the stages cause watever I do it will never work right ...just want the high end vtec to kick in and not run so rich
Old Apr 23, 2014 | 06:59 PM
nub's Avatar
nub
It doesn't matter what you think you want. You'll never pass the low/high idle speed emissions test. I doubt you'd even get past the visual inspection.
You need to get a D15B7 or D16Z6 and be done with it if you're going to stay SOHC.
Old Apr 23, 2014 | 08:37 PM
lerks909's Avatar
No turning back already in my car ...i had a d16a6 in my car and thats a obd0 engine and passed smog with a p06 ecu and Obd1 harness
Old Apr 23, 2014 | 09:18 PM
raverx3m's Avatar
im guessing you re on your own at this point do research.
I did when I swapped a d15z1 into a civic. and found all info that I needed
Old Apr 23, 2014 | 09:22 PM
raverx3m's Avatar
best thing you could do is pick 2 cam profiles out of 3 and match the fuel/ignition maps from 2 different basemaps into one so it runs
Old Apr 24, 2014 | 03:44 AM
The Grumpiest
Yeah. Then he screwed up. I don't think if money was an issue that I would not have research way more than the OP did before dropping any coin on an engine I knew absolutely nothing about.
Old Apr 24, 2014 | 04:50 AM
lerks909's Avatar
Your right I didn't know anything about this engine and I will learn from mistakes..thx for the help raver
speedbump79
Nov 30, 2017 05:12 PM
3stage96
24
Jun 9, 2015 09:49 AM
ronald55555
Oct 23, 2006 07:55 PM
bitzbp
Jun 2, 2003 02:19 PM
