new battery-new starter-no start
Old Apr 10, 2014 | 05:54 PM
kimbothegiant's Avatar
Default new battery-new starter-no start
Hello All,
New battery, new starter. When I turn the key, lights come on the dash but no click, or crank. I can hear the fuel prime so that's not the issue and the fuel filter was recently replaced. Checked the fuses and didn’t see any problems. Before replacing the starter I would get an occasional crank but no start. Now, not even a crank. The indicators before the new battery and starter were, the wipers moving slowly and the electrical would shut down and come back on while driving. Weird. Could it be the alternator?
Thanks,
Old Apr 10, 2014 | 06:45 PM
existanzcivicb20's Avatar
Default Re: new battery-new starter-no start
I would check fuses and hit the starter with a hammer to see if that helps (no joke). If not always check, disconnect, and clean all grounds.
Old Apr 10, 2014 | 07:45 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
What year and trim of car, any mods?
No car information makes it even more challenging to provide solid information. Also is it a manual or automatic transmission?
Old Apr 11, 2014 | 06:41 AM
Del Sol 1.5L 1994 automatic. Had the salvage parts guy test the starter in front of me before buying it. My wires from battery to starter look good. The fuses in the engine look good. I have a multimeter. What do test on the starter to confirm power from battery? The S terminal and what else?
Old Apr 11, 2014 | 08:30 AM
instrument's Avatar
Either clutch relay switch or ignition, you can jump the switch to test.
Also try to bump start the starter directly from the battery.
Other then that, do you have an alarm?
Sounds like clutch switch though
Old Apr 15, 2014 | 01:14 PM
You know, I do have a alarm system. The auto repair shop disconnected or pulled the fuse because it would not disengage. I drove the car many miles after that with alarm disengaged. Also, my Del Sol is an automatic. Would it have a clutch switch?
Thanks
Old Apr 15, 2014 | 04:06 PM
carlos8's Avatar
check with a test light if the ST cable is getting signal when turn the switch to ONIII.
Aquila
20
Sep 28, 2016 05:59 PM
JJT211
Jun 22, 2014 08:33 PM
Mike518
Aug 29, 2012 11:29 AM
Jonathan_ED3
Aug 14, 2008 06:15 PM
go2sleep
May 6, 2007 08:42 PM
