something hissing after car is shut off (video)
Old Apr 10, 2014 | 02:32 PM
swizz977's Avatar
Default something hissing after car is shut off (video)
im not sure if this is normal but when i turn my car off it sounds like a air leak coming from my brake booster area I'm not sure actually maby power steering but it could be making that noise while the engine is running too i wouldn't be able to hear it
it makes the noise for about 5 seconds after the car is off and then stops heres the link to the video.. might have to turn your volume up a little
https://www.facebook.com/photo.php?v...42027082894512
Old Apr 10, 2014 | 03:36 PM
ef2_civic's Avatar
Default Re: something hissing after car is shut off (video)
I had this leak a minute ago. Check the hose clamps on the lines to and from the booster to manifold. I tighten them all a bit and all gone. No more leak for me
Old Apr 10, 2014 | 03:54 PM
swizz977's Avatar
nope doesnt seem like its those hoses.. its frustrating i cam hear it but cant fint it.. sounds like its coming from the master
Old Apr 10, 2014 | 03:58 PM
swizz977's Avatar
found it coming from the bottem of the master and the brake booster
Old Apr 10, 2014 | 04:34 PM
swizz977's Avatar
so what exactly is the problem the master?
Old Apr 10, 2014 | 05:24 PM
swizz977's Avatar
or just a gasket?
number 3?
Old Apr 11, 2014 | 07:55 AM
swizz977's Avatar
anyone?
Old Apr 11, 2014 | 03:49 PM
swizz977's Avatar
help please?
Old Apr 11, 2014 | 06:06 PM
blazzer's Avatar
could you be a little more specific with the pic as to where the leak is coming from. in your pic it looks like a massive crack below the MC.
If that is teh case i think you will need a new brake booster. or did you find the leak coming from right behind the MC where it bolts up to the brake booster?
if so then i would say it is not sealed properly. but the details area little vague.
please be a lil more clear. and specific
Old Apr 12, 2014 | 01:04 PM
swizz977's Avatar
here looks like the booster is cracked
Old Apr 12, 2014 | 01:06 PM
swizz977's Avatar
but i took a metal bruch and cleaned it up i think it was just rot rust crack it looks like a bad seal?
Old Apr 12, 2014 | 01:18 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
um, the master isnt sealed to the booster, thats a dust seal, the rubber piston seals in the booster are sealed inside, when you push on the brake, you push on the rod in the booster,which pushes another rod, that operates the master, if the booster failed, you will still brakes, the pushrod in the booster acts directly on the master pushrod
Old Apr 12, 2014 | 01:23 PM
http://auto.howstuffworks.com/auto-p...wer-brake1.htm
Old Apr 12, 2014 | 07:22 PM
swizz977's Avatar
ok im just trying to figure out why theres air leaking out of there
Old Apr 12, 2014 | 09:59 PM
it's air possibly leaking in, there is no pressure in the booster, if the diaphragm is bad, air will try to make it's way back into the booster diaphragm, if you pull the master cylinder and see fluid where the rear seal on it is, then it's probably leaked into the booster, and ruined it.
Old Apr 13, 2014 | 07:25 AM
crazyhouse2011's Avatar
Do you have an aftermarket intake?
Old Apr 13, 2014 | 07:44 AM
what does that have to do with the booster? the booster is in bad enough shape to be cracking, the diaphrams inside of it are probably shot also
Old Apr 13, 2014 | 06:52 PM
swizz977's Avatar
ok so what do i need a new booster?.. i replaced the master a couple years ago
Old Apr 14, 2014 | 12:50 PM
swizz977's Avatar
so its a bad master again? thats wierd i replaced it a few years back
Old Apr 14, 2014 | 12:53 PM
JoeBlue's Avatar
Replace the booster or eliminate it.
Old Apr 14, 2014 | 03:07 PM
swizz977's Avatar
ok some people are tellin me to replace the master but u think i should replace the booster?
Old Apr 14, 2014 | 03:12 PM
Usually when i shut the car off there's like a full second of hiss from my intake.
JDM JUNKIES 1
Mar 12, 2013 12:19 AM
n00bfasho
Dec 28, 2006 06:38 PM
ef8sleepr
Feb 28, 2006 09:33 PM
GroundZer0 336
Nov 19, 2003 01:36 PM
wessieball
Jan 2, 2003 09:23 AM
