jdm eg6 cluster - how make brighter amber?
Any have any success with making the cluster brighter amber?
I tried white led and its too bright and white. Tried red and its all bright red.
Any success or ideas? If not I might just have to live with the dim amber lighting in the cluster.
Alright i'll check it out..
Not sure how your LED bulbs are constructed. If you can take it apart from the base, you can solder in a resistor and it will dim the LED. The fun is soldering it in and having it all fit back into the base without issue.
If it already has a resistor, you just need to swap it with a higher resistance one to reduce the brightness.
All your dimmer is, is a variable resistor (Potentiometer), and probably wired onto itself turning it into a Rheostat. Been to many years, forgetting terms.
http://www.trait-tech.com/uploads/de...ight-Bulbs.jpg
I musta been tired last night, I read your topic as how to dim the amber....
You want a brighter bulb not dimmer.
My error.
If your LED's have a resistor you would want to reduce the resistance to brighten the bulb.
That surface mount part numbered 221 is most likely a resistor. If you get a less resistance one and swap them (PITA to do with surface mount parts but can be done) then you will get a brighter LED. The consequence is the LED may not last as long being more current is going through it. It could potentially burn it out sooner instead of later.
My error.
Mario.
Jan 15, 2005 10:21 PM
itsJDMyo
14
Oct 19, 2003 05:22 PM
