94 civic si abs delete
Old Apr 9, 2014 | 11:29 AM
thrashfan666's Avatar
Default 94 civic si abs delete
I want to do an abs delete on my 94 civic si. Im not really sure what brake components I can reuse and which ones I have to get. If someone could help me out with a list of parts I will need, that would be great. Thanks.
Old Apr 9, 2014 | 05:44 PM
JoeSatov's Avatar
Default Re: 94 civic si abs delete
The ABS system is really just wheel speed sensors, fluid pump and a brain....so I guess if you wanted a full on delete you need to swap out axles and speed sensors, remove the ABS pump and install brake lines, and remove the brain/controller. It very well may be part of the ECU though.
Or I guess just pull the fuse. Seems like a large cost and hassle to remove the entire system...If you are looking for weight savings I would look elsewhere. If you don't like the way the system responds I would just disable it...
Fibercation
Suspension & Brakes
Apr 7, 2009 07:28 PM
jmai86
Jul 2, 2007 01:29 AM
Bad-T
13
Nov 17, 2004 02:49 PM
orangebarius
Sep 11, 2004 08:20 AM
Greyout
Oct 13, 2003 12:17 PM
