OBD2 -> OBD1 -> OBD0 Distributor Wire Mapping
Old Apr 8, 2014 | 10:53 AM
mdrouillard1983's Avatar
Default OBD2 -> OBD1 -> OBD0 Distributor Wire Mapping
Anyone needing to map wires or convert harness from one OBD to another I just put together a nice diagram to help. All the way from OBD2 down to OBD0 since I am doing this for my VTEC project, hope it helps someone else too.
Old Apr 8, 2014 | 11:16 AM
4drEF's Avatar
Keyboard Humorist
Default Re: OBD2 -> OBD1 -> OBD0 Distributor Wire Mapping
Do you have the OBD2a spec to add to it?
Old Apr 8, 2014 | 11:44 AM
Good call, I'll see if I can dig it up and re-do the diagram with OBD2A/B
Old Apr 8, 2014 | 12:03 PM
I've updated the diagram, if anyone could please verify and double check my work it would be great.
Got updated info, if anyone is doing this; there is a BLUE wire coming from the OBD0/OBD1 engine harness this is for the Tachometer output which OBD2B does not have (OBD2A does).
Simply run a wire into the distributor housing, and tap into the ignitor housing there is a lead that is not used it is at the base of the rotor assembly impossible to miss; this should send the proper signal.
Reason is that OBD2B ECU gets RPM from the other sensors (CKP/CYP). But in my case running with a P28 OBD1 ECU needs this readout.
Now to see once put all together if it works...
Old Apr 10, 2014 | 09:12 AM
24TEN's Avatar
PHANTOM MENACE
Nice catch on the RPM signal for the OBD2B distributor. I was just about to point that out.
Old Mar 29, 2015 | 06:00 AM
99teggsr's Avatar
With all the distributor pinouts on the internet im going to take a chance and go with this one. Before I start cutting and soldering, can somone confirm this one is good ?? Everyone and their brother likes to make one of these, some with varying wire colors and positions. wish we could erase the internet of all of these images and have one agreed upon diagram.
Old Mar 18, 2018 | 01:43 PM
griggc's Avatar
Icon6 Re: OBD2 -> OBD1 -> OBD0 Distributor Wire Mapping
I dont follow the underlined comment, ive heard that the blue rpm wire from OBD1 can run into the dash cluster ??
Old Mar 20, 2018 | 10:32 PM
Marcos Barrios's Avatar
yes the wiring is correct
in my build thread
(Marcos new work car 90 sedan)
i am running the obd2 dizzy
wired just like in the picture with no problems for over a year now
dfanatic86
Mar 5, 2014 05:23 AM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
turbo77nyc
Sep 22, 2006 05:20 AM
ExplicitSpeed360
May 28, 2006 08:21 AM
revlimitcrx
Apr 2, 2006 12:29 PM
