clutch master cylinder?
Old Oct 29, 2002 | 07:17 PM
3rdGteg's Avatar
Default clutch master cylinder?
Is it only bad if they start leaking? How do u know really if the clutch master cylinder is bad? My tranny sometimes don't wanna go into gears until I pump the clutch pedal a few times. I replaced the slave cylinder and bled it until pedal is stiff, but once in awhile as I'm driving, it'll feel a little softer and I have to pump the clutch a second time to get it into gear. The clutch kit is new, slave is good, the system as no air, and the reservoir is always full w/ no signs of leak anywhere; so I'm doubting it's the master cylinder, but many have suggested it in the past. what ya'll think?
Old Oct 31, 2002 | 09:42 PM
3rdGteg's Avatar
Default Re: clutch master cylinder? (3rdGteg)
ttt
Old Oct 31, 2002 | 10:04 PM
Evs-One's Avatar
Solbros Owns Me
there is no master cylinder, only for brakes. There's the resevoir and the slave cylinder on the transmission itself. If it's not leaking fluid it should be ok. Did you replace with an OEM unit? Try flushing out the fluid and putting in a brand new bottle and re bleed it.
Old Nov 1, 2002 | 02:24 AM
rob d's Avatar
Default Re: clutch master cylinder? (Emerica)
There is a clutch master cylinder. I just changed mine. Did you try to bleed it first? Mine was leaking. Look inside the car and see if it is leaking. My carpet had oil on it.
Old Nov 1, 2002 | 10:38 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: clutch master cylinder? (rob d)
where's the clutch master cylinder? Are you talking about the slave cylinder on the tranny?
Old Nov 1, 2002 | 11:05 AM
nsxmatt's Avatar
The slave cylinder is on the tranny and what they are talking about is the little cylinder below where the fluid goes in.
Old Nov 1, 2002 | 09:27 PM
3rdGteg's Avatar
Default Re: clutch master cylinder? (nsxmatt)
I bled the **** out of it and the pedal is stiff. My fluid is always full, so I doubt that it's leaking. I also already changed out the slave cylinder just in case but it wasn't that. The problem is when I'm driving and come to a stop I can't get it into gear because the clutch gets a little mushy sometimes so I have to let up all the way and depress it (pump it) a couple times until I hear this weird click on my clutch pedal and after it clicks, it is then able to go into gear
Old Nov 4, 2002 | 05:40 PM
3rdGteg's Avatar
ttt
Old Nov 4, 2002 | 06:22 PM
salbaje's Avatar
you can adjust the pedal from under the dash just screw out the rod and try it.
if not try bench bleeding the master cylinder.
Old Nov 4, 2002 | 07:44 PM
3rdGteg's Avatar
Default Re: clutch master cylinder? (salbaje)
I thought u really can't adjust hydraulic setups? Anyway, can u please explain more in detail on how to adjust the rod and whatever u mean by "bench bleeding" the master cyl.
Thanks.
Old Nov 5, 2002 | 01:22 AM
b19coupe's Avatar
"Bench bleeding" means bleeding the master cylinder on the bench as opposed to being in the car. This usually applies to brake master cylinders. As far as adjusting the rod goes, if you lay your head on the floormat and look up at the rod going to your clutch pedal from the master, you will see a 12mm locknut on the rod where it attaches to the clutch pedal. Loosen the 12mm locknut and turn the rod to adjust freeplay. Then lock it in place with the 12mm locknut.
If I were you I would bleed the clutch some more, several times in fact. If you still have a problem, it may be that the problem is mechanical in nature and not hydraulic.
Old Nov 5, 2002 | 05:27 AM
Chiovnidca's Avatar
I've seen a couple bad clutch master cylinders doing what you describe.
Old Nov 5, 2002 | 01:21 PM
3rdGteg's Avatar
Default Re: clutch master cylinder? (b19coupe)
[QUOTEIf you still have a problem, it may be that the problem is mechanical in nature and not hydraulic. [/QUOTE]
Thanks for the info on adjusting the rod. You said it could be mechanical, like what?
JDMswagSerf
Dec 10, 2013 09:47 PM
siregcivic
Oct 16, 2005 07:55 PM
714JDMBB4
Aug 29, 2005 05:34 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
b20civic
Aug 5, 2002 09:09 AM
