Stuck Valve?
I've seen valves stuck in broken engines when remove the head. If the engine stay together it not rotate!!
But what most people call stuck valve in running engines is a bent valve. Basically a compression or leak down test should tell you.
denierlexiese
Aug 31, 2015 08:16 PM
