alternator and fusebox with ELD questions
Old Apr 5, 2014 | 06:11 PM
Canadian_EF's Avatar
Default alternator and fusebox with ELD questions
Hi.
So I finished my swap and took it out for a drive and it died after a few mins of driving. It died as if power was lost. I'm running an odyssey Pc680 in the trunk of my 89 civic hatchback.
I have a 2 pole cut off switch that is wired like so:
Battery and alternator on one side.
Fusebox and starter on the other.
I'm running an accord alternator with innovative's h series bracket. Would the paint cause the alt to not ground?
On the fuse box, does anything need to be hooked to the alternator terminal? My fusebox has an ELD if that makes a difference.
I'm getting adequate voltage from the battery so I know it has to do with the alternator.
Speed--Freak
15
Jan 5, 2022 05:22 AM
obuhmyuh
May 28, 2008 03:27 PM
aziaticvang
Jan 7, 2008 03:59 PM
eg6madness
Oct 28, 2006 01:37 PM
bonta-kun
May 12, 2003 06:08 PM
