89 1.5 ECU blinks continuously
Old Apr 5, 2014 | 06:25 AM
DCcrx's Avatar
Default 89 1.5 ECU blinks continuously
89 CRX 1.5. changed rotor cap, rotor and plug wire. after that it seemed to run smooth, around the block. The next day, leaving for work and about 5-10 miles down the freeway my Check engine light came on. got back home and turned ignition off then on. the ECU started blinking and after, about 60 blinks i turned it off and went to work. what could it be? thanks.
Old Apr 5, 2014 | 09:31 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: 89 1.5 ECU blinks continuously
O2
Old Apr 5, 2014 | 09:53 AM
DCcrx's Avatar
change it? any way to check it to see if bad? thx. is there 1 or 2?
Old Apr 5, 2014 | 12:54 PM
99teggsr's Avatar
Just one 02 sensor on our cars, its one wire, white, and is easily accessible as it is right on the top of the header. You could make sure it is plugged into its connector well by unhooking the two connectors and reconnecting 2 or 3 times. Then pull your ground cable, wait 30 seconds, re-install. If it comes back on you have a bad 02 sensor.
Old Apr 5, 2014 | 01:27 PM
DCcrx's Avatar
thx, will try. Ground cable? the one on the valve cover? if so, i noticed that wire looked old and tired! i loosened it ti straighten it out. i"ll replace it any ways. thanks again.
Old May 19, 2014 | 09:34 AM
Mark Anthony's Avatar
Did you ever figure your problem out??? I have the same problem
Old May 26, 2014 | 07:58 AM
DCcrx's Avatar
no, after the first drive it never came back! figured it was broke so i drove the hell out of it to see what happens. the only thing i did was mess with the distributor and wires. Moved the Ground wire around on the valve cover. probably blew some thing through there!? hope you find the problem. thx.
Jeffrey9
Mar 21, 2006 08:26 AM
silverboost
Oct 17, 2005 11:21 AM
dingusjt
Nov 13, 2003 10:18 AM
Maverick77
Nov 22, 2002 07:50 PM
