b16 running weak, revs limited to 3500
Old Apr 4, 2014 | 10:38 AM
em1goesbwah's Avatar
Default b16 running weak, revs limited to 3500
Hi forum. This problem is constantly getting worse and I need to find out what it is asap. Car is a 1998 civic si(Canada) with obd1 b16a sir2 p30 ecu. What happens is most of the time when I start it it goes into what I assume is limp mode because it feels like it is bogging down hard and then backfires when I get to 3500 rpm. The CEL also comes on as CKP crankshaft position sensor every time it goes into this mode. Sometimes it will start without this code (primarily if I start it while giving it some gas) but after a couple miles or minutes it boggs out and goes into this mode.
What I've done:
Plugs, wires, cap & rotor, ign timing, timing belt (dead on). I checked the ckp sensor using the dizzy plug and its reading .350 ohms (within 350-700 range?) I also read somewhere to check if you IACV works take off intake and look inside TB to see if something moves when key is turned to on position - nothing happened. So im not sure if that's an issue.
I'm just really confused because the car ran like a dime before winter and now in spring its running like a bag of **** when it goes into this mode. Otherwise the car runs fine (like 20% of the time). Please help!!!! Thanks
Old Apr 4, 2014 | 03:36 PM
carlos8's Avatar
Default Re: b16 running weak, revs limited to 3500
CEL 4, plus the CKP is in the low limit of the range.
I will try another distributor and reset the ECU and see what happens.
Maybe borrow one from a friend!!
Old Apr 4, 2014 | 11:37 PM
aric_hatch's Avatar
try another ecu! ive had the same problem
Old Apr 5, 2014 | 01:53 AM
HondaPartsHero's Avatar
Technical Hero
Old Apr 5, 2014 | 02:01 AM
turbomaniac's Avatar
try another crankshaft position censor..
B16a_delsol94
11
May 8, 2011 12:10 PM
honda305
Sep 10, 2010 07:30 AM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
PINKS
Aug 2, 2006 02:43 PM
ef dino
Jul 6, 2006 06:58 PM
