Steering Wheel shaking
Old Apr 4, 2014 | 07:31 AM
Uljima's Avatar
Default Steering Wheel shaking
Hi, I have a civic 2000 hatchback, with a b18b1 swap. My steering wheel shakes/vibrate viciously when at idle and any gear it gets really annoying. I even tried taking it out and righting the bolts. I have stock mounts from my d16 on my b18b1 would that be the problem? The whole car is vibrating but it's not as much as the steering wheel. What should I do
Old Apr 4, 2014 | 10:29 AM
Shanasman12's Avatar
Check all your tires. My wife's KIA did the same thing. I didn't know what it was until the tire blew out on us while driving down the highway. Turns out there was a huge bulge in the front passenger side tire.
Shanasman12
Old Apr 4, 2014 | 05:19 PM
If that isn't the problem you may need to get your wheels balanced and aligned.
Shanasman12
Old Apr 4, 2014 | 06:19 PM
slowcivic2k's Avatar
Default Re: Steering Wheel shaking
What is your idle speed? Low idle will cause uncorrectable shaking without making the mounts soft as hell.
Mounts that are too stiff or do not transmit vibration into the chassis evenly can result in engine shake. Are you using 5 mounts or 3?
Exhaust?, any leaks under the car?
Old Apr 5, 2014 | 12:53 AM
underrated's Avatar
Make sure to torque your mounts in sequence. You can find the correct sequence in the fsm.
Old Apr 5, 2014 | 02:34 AM
Not saying don't take advice from people here but careful when you ask a question like this or you could end up with a mile long list of things you need to check to find out what's wrong when its something simple like the tires. I'm not saying don't check the mounts or anything, but check the easy stuff first. (Of course you probably already know this so my response is likely redundant)
Shanasman12
Old Apr 5, 2014 | 04:20 PM
underrated's Avatar
OP said it shakes at idle, so how can it only be the tires?
Old Apr 5, 2014 | 04:27 PM
You're right. My bad, I must have missed that
Shanasman12
And I didn't say it was ONLY the tires. Just saying check the easy stuff first is all.
Shanasman12
Old Apr 6, 2014 | 02:17 AM
underrated's Avatar
Shanasman12
Agreed.
Reason why I said check the mounts is because it happened to me.
Old Apr 6, 2014 | 07:51 AM
hybridmiklo's Avatar
Wait, you said you have your d16 mounts with the b18? So the swap is sitting crooked and thats why it vibrates
Old Apr 8, 2014 | 08:07 PM
Correcting the tires is secondary, correct the idle vibration first, and then proceed to diagnose a rolling vibration. Tires/balance/rim size will have a profound effect on vibration. You will need to inspect your car to determine what is physically wrong, and then diagnose the cause.
Herbie
31
May 13, 2015 06:34 PM
raverx3m
Mar 10, 2015 08:15 PM
Dekorum
26
May 11, 2012 03:44 PM
raverx3m
Nov 24, 2010 04:11 PM
alwaysoverkill
Dec 6, 2006 08:45 AM
