92 accord trouble starting and hesitation/stalling
Old Apr 3, 2014 | 07:49 PM
help wanted's Avatar
Default 92 accord trouble starting and hesitation/stalling
Someone please help I have a 92 accord that has a hard time starting. When I turn it on I turn it over for 4 seconds and it doesn't start, I turn the key off and turn it over again it starts fine. When I hit the gas it putters and stalls if I keep the gas pushed. If I slowly accelerate the gas in parked it will rev up and once it starts to rev I can rev it hard does the same in drive but is more sensitive
Ive cleaned the fast idle thermal valve and idle air control valve, checked for vaccine leaks new cap and rotor wires and plugs, new fuel filter, bleed the coolant system for air and tested egr valve
Old Apr 3, 2014 | 08:13 PM
ej7attack's Avatar
Default Re: 92 accord trouble starting and hesitation/stalling
you getting any codes?
you verify the iacv is actually functioning properly?
check fuel pressure?
coolant temp sensor?
also check coil and ignitor and verify your getting good spark.
Old Apr 4, 2014 | 01:10 AM
holmesnmanny's Avatar
first thing i would test when having problems starting is the engine coolant temperature sensor ... should be 2000-2500 ohms when the engine is cold and 180-250 ohms when the engine is warmed up fully
Old Apr 4, 2014 | 07:01 AM
dahubby's Avatar
Check the fuel pressure from the pump. It sounds like it may be low...
Old Apr 4, 2014 | 12:30 PM
Checked the fuel pressure fuel pump is good an checked the thermal control valve also good I was told the full line ruturn could be clogged is this possible and how do I check
Old Apr 4, 2014 | 02:31 PM
ej7attack's Avatar
take your gas cap off and start up. any difference?
Old Apr 5, 2014 | 10:09 AM
Didn't change anything
Old Apr 6, 2014 | 07:25 AM
Lost Again's Avatar
Does this happen all of the time or only after the car has sat for a while?
Old Apr 6, 2014 | 07:34 AM
accordturb96's Avatar
sounds like the pump is bleeding pressure just after the key is turned on. It may have pressure but if it drops right away there is something else wrong even an injector issue
Old May 1, 2015 | 01:30 PM
vfeezy's Avatar
Did you ever figure out what was causing your issue? I am having the same issue. I replaced my Igniter, new battery and alternator. Could it be the air boost valve?
Loughf
Mar 19, 2014 03:54 PM
bochnak
Nov 11, 2010 04:42 AM
ChevelleSSLS6
Aug 27, 2010 06:24 AM
Maireeka
Nov 26, 2007 04:55 AM
bigrush2006
Feb 5, 2007 08:05 PM
