Repeated GSR Valve Adjustment..
Old Apr 2, 2014 | 10:19 PM
Bplavery24's Avatar
Default Repeated GSR Valve Adjustment..
SO, a while ago i miss shifted and accidentally went into 2nd (instead of 4th) from 3rd right at rev limiter. Bounced and over-revved a bit before i put in the clutch, but nothing too dramatic happened.
No power loss and everything ran fine after but my engine was pretty noisy. Did some research and determined i needed a valve adjustment. Once i got the clearances back to stock, the "tick" went away and everything was great.
Problem is, a month of DD later and the "tick" comes back. I adjust my clearance again, "tick" goes away.. until another month or so
WHY DO I HAVE TO KEEP ADJUSTING MY VALVE CLEARANCE???
Valve springs / retainers..? Rocker arms..? I'd rather just fix whatever is going on before i adjust my clearance again (for the 4th damn time ahah..)
Any ideas??
Old Apr 3, 2014 | 04:42 AM
Flr Power's Avatar
Default Re: Repeated GSR Valve Adjustment..
You probably bent some valves...or something
You will need to remove the head to inspect the valves...
Old Apr 3, 2014 | 08:46 AM
Bplavery24's Avatar
Really, bent valves? My idle is fine, no power loss :S I dont want to take my head off just to find that they're ok..
Old Apr 3, 2014 | 08:54 AM
turbomaniac's Avatar
mabe there is a problem with one, ore more of your valve or valve seats...
you are lucky that you have only to adjust valve crearence...
Old Apr 3, 2014 | 11:25 AM
Flr Power's Avatar
Do a leak down test. Most engine I saw that over speed like you say it did end it up with a dropped valve in one of the cylinders.
Old Apr 4, 2014 | 12:31 PM
Bplavery24's Avatar
Alright sounds good, i should be able to get similar results with a compression test eh? i dont have access to compressed air.. If it is off i'll take off the head and see what my valves and seats are looking like
Old Apr 4, 2014 | 12:42 PM
leack down test is more accurate than the compression test, but i would suggest first do the compression test, because it is much easier...
Old Apr 4, 2014 | 03:12 PM
Bplavery24's Avatar
Compression Test:
170 / 165 / 140 / 165
Looks like #3 took some damage after all.. I'll find some time next week to take the head off and check out my valves / seats
Old Apr 4, 2014 | 03:25 PM
well done...
i hope you fix it soon...
after the job done and before you rebuild the head, do the leack down test...
Old Apr 5, 2014 | 09:32 PM
Bplavery24's Avatar
Will do, thanks for the advice!
raverx3m
May 18, 2011 11:24 PM
EH3forlife
12
Jan 20, 2008 07:55 PM
luvinmyGSR
Mar 21, 2004 07:47 PM
typesguy
Aug 7, 2003 11:00 AM
