AC Noise
Old Apr 2, 2014 | 09:54 AM
miamihonda's Avatar
Regarding a 96 Civic with LS swap. AC works fine however after it has been running for approximately 15 minutes (always the same amount of time) there is an unusual noise that comes from the AC related boxes behind the dash. It sounds sort of like air whooshing or a very very quiet air compressor building pressure. The AC continues to work fine as this happens. I've had dozens of Civic's and don't recall hearing this noise before. Could this be something to do with the evaporator?
Old Apr 2, 2014 | 10:18 AM
Former User's Avatar
Default Re: AC Noise
You are hearing refrigerant spraying into the evaporator - not abnormal.
Old Apr 2, 2014 | 10:46 AM
miamihonda's Avatar
Would this noise be more pronounced if the freon is low? I have to check it later.
Old Apr 2, 2014 | 10:52 AM
If your A/C works fine, I would do nothing.
Old Apr 2, 2014 | 11:12 AM
miamihonda's Avatar
thanks, i'll leave it be. the only reason i posted is because i hear this noticeable "injection" every 30 seconds or so only AFTER the AC runs for 15 minutes silently.
Old Apr 2, 2014 | 11:19 AM
Post a video with sound or just sit back and enjoy a working A/C system.
gooeymax
Aug 30, 2018 04:33 AM
DeeJaayM
Honda Civic (2006 - 2015)
Jul 16, 2018 08:16 PM
01-1293
10
Jul 19, 2006 02:02 AM
elpiar
Mar 22, 2005 03:50 PM
