96 ITR Brake Tech Thread
Old 05-23-2003, 07:04 AM
KOALA YUMMIES's Avatar
Default ,.
Old 05-23-2003, 07:07 AM
Spade's Avatar
Default Re: 96 ITR Brake Tech Thread (KOALA YUMMIES)
If I were to do it, I would "repair" with Brembo OEM replacements and slightly aggressive pads.
The brakes are large enough as is.
Old 05-23-2003, 07:09 AM
Default Re: 96 ITR Brake Tech Thread (Spade)
Maybe you dont understand the problem???
THERE NEVER WAS A TYPE R IN THE US IN 1996, so there are no 4-lug (4x114.3) rotors available from dealerships or companies here...
Old 05-23-2003, 07:12 AM
kommon_sense's Avatar
have you considered getting a set of USDM ITR rotors and having them redrilled to 4x114.3?
Old 05-23-2003, 07:15 AM
Spade's Avatar
I'm sure if you contact Brembo, they would have them.
Old 05-23-2003, 07:28 AM
Nextelbuddy's Avatar
i too thought of this that is what deterred me from doing the 4 lug type r brake conversion and i just went ahead with the gsr front and rear conversion. i knew that the rotors would eventually give out and i wouldnt be able to find replacements as easily or as cheap as the gsr. the BLING factor wasnt worth it to me. i asked this question b4 knowing and have seen a as load of people do the 4 lug type r swap and no one wanted to answer its liek they want to keep it to themselves or they dont know either.
Old 05-23-2003, 11:07 AM
Ok... I was under the impression that the Honda accord front brake caliper/rotor set was the same as what was on the ITR. Weren't some of the older model accords 4x114.3? I'm just going on tidbits that I remember from random posts. It may be time to measure the dimensions on one of your rotors and go to an autoparts store and find an oem rotor that fits. Honda tends to reuse things, so there has gotta be another honda/acura that uses the same rotors.
Old 05-23-2003, 12:13 PM
VX
VX's Avatar
Default Re: (kommon_sense)
Talk to SpooN Man (Holding a Group Buy on Fast Brakes).
I PM'ed about this very topic, here is the conversation:
(8:07 PM 5/18/2003) VX: I was wondering if Fast Brakes, makes any rotors that are for the 96 Spec. JDM ITR 4-lug wheels??? They are 4X114.3
(5:52 AM 5/19/2003) SpooN Man: yes they are the same as lude rotors. I'll e-mail brian about it.
(12:55 PM 5/19/2003) VX: are these rotors the same diameter, width as Fastbrakes' GSR rotors, just with a different spindle pattern???
(1:22 PM 5/19/2003) SpooN Man: yes, I think that they are the exact same but drilled for your 4 x 114 app. Lude 4 lug rotors are the same size also.
Modified by VX at 2:12 PM 5/23/2003
Old 05-23-2003, 12:22 PM
VX
VX's Avatar
Default Re: (VX)
Here's a pic of a replacement rotor for the 4x114.3 lug pattern. I'm almost positive that i got this pic from a member here on H-T. I don't remember who the member is or what kind of rotor this is.
Old 05-23-2003, 12:30 PM
jonas's Avatar
PM "KJEG94" here on h-t. he went through hell and back with his 96 spec ITR 4x114.3 lug conversion.. he knows about this part too.
Old 05-23-2003, 01:27 PM
VX
VX's Avatar
Default Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">PM "KJEG94" here on h-t. he went through hell and back with his 96 spec ITR 4x114.3 lug conversion.. he knows about this part too.</TD></TR></TABLE>
(1:36 PM 5/23/2003) VX: Hi, what replacement rotors did you find out that will bolt onto the 96 Spec. ITR hubs (4X114.3)??? BTW: nice site man, cool photos!
(1:47 PM 5/23/2003) KJEG94: thanks man. i ended up using 96 USDM gsr rear rotors. Redrilled by a machine shop to 4x114.3 and bored out in the center to fit the hub. Its only a slight amount to bore but if u have a stock jdm rotor they can match it
(2:09 PM 5/23/2003) VX: ahh i see, thanks man!
Old 05-23-2003, 06:30 PM
CXHatchback's Avatar
Default Re: (VX)
I don't understand the point of getting the 4x114.3 conversion, is there something I'm missing? Aren't the brakes teh same as gsrs? What would make you choose to do this, aside from being "different"?
Old 05-23-2003, 06:34 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (CXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">I don't understand the point of getting the 4x114.3 conversion, is there something I'm missing? Aren't the brakes teh same as gsrs? What would make you choose to do this, aside from being "different"?</TD></TR></TABLE>
same as GSR plus different wheel selection.
I think 800 bucks for a nice 4 disc setup plus mint wheels is a very good buy
Old 05-24-2003, 07:19 AM
SamB16's Avatar
Default Re
ok guys, use 92-96 Prelude VTEC Rotors (11'') I haven't actually done any 96 ITR swaps yet but that would be my assumption. If the 96 discs are actually smaller then I would say you should try the the two different types of Accord/Prelude discs.
Honda Accords at one point came with a ******* weird disc, it may be that one. I'll give you both part numbers (Brembo)
094 2927
094 2924
one of those is a two piece ...... hope that helps you guys out
The above brake set looks like it uses 92-96 Prelude NON-VTEC
Modified by SamB16 at 4:31 PM 5/24/2003
Old 05-24-2003, 12:57 PM
VX
VX's Avatar
Default Re: Re (SamB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamB16 &raquo;</TD></TR><TR><TD CLASS="quote">ok guys, use 92-96 Prelude VTEC Rotors (11'') I haven't actually done any 96 ITR swaps yet but that would be my assumption. If the 96 discs are actually smaller then I would say you should try the the two different types of Accord/Prelude discs.</TD></TR></TABLE>
Ok, it's been confirmed that Prelude NON VTEC rotors don't work as a
replacement rotor, but can somebody confirm from experience if the
Prelude VTEC rotors will bolt up and fit as a replacement rotor??????
Old 05-24-2003, 11:54 PM
VX
VX's Avatar
Default Re: Re (KOALA yummies)
Ok based on what Koala Yummies is saying... Prelude VTEC, and Non-VTEC, and Accord rotors will not work as replacement rotors... Instead of re-drilling GSR rotors... DOES ANYBODY KNOW WHAT AFTER MARKET BRAKES (ROTORS & CALIPERS) WILL WORK???
Old 05-25-2003, 04:34 PM
B_CRUZ!'s Avatar
Default Re: Re (VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Ok based on what Koala Yummies is saying... Prelude VTEC, and Non-VTEC, and Accord rotors will not work as replacement rotors... Instead of re-drilling GSR rotors... DOES ANYBODY KNOW WHAT AFTER MARKET BRAKES (ROTORS & CALIPERS) WILL WORK???</TD></TR></TABLE>
re-drilling GS-R rotors are the best way to go IMO. The 93 prelude VTEC brakes go on the hub but YES they are a bit bigger. 11" if I am not mistaken.
Do you know what that means? It means a OEM Honda big brake upgrade. Yes kiddos you can bolt on 93+up caliper bracket and caliper in the front Woowooo!!!! You have to shave a little on the caliper to where it mounts.
Old 05-25-2003, 06:56 PM
VX
VX's Avatar
Default Re: Re (B.CRUZ)
Any threads, detailed info, or pics, of fitting the prelude rotors and calipers on the ITR hubs??? (Shims, Shaving Calipers... etc.)
Old 05-26-2003, 12:23 AM
VX
VX's Avatar
Koala, post any info you receive from Fast Brakes when you talk to them regarding their replacement rotors for these hubs.
Old 05-26-2003, 01:03 AM
Quik Chris's Avatar
Yeah, I know I've talked to VX and Koala Yummies about this, and I'm having my doubts about the Prelude Rotors. Maybe the 3rd gen ones might work? Or maybe my rotors are just odd-ball as hell and I'll have to redrill eventually. Though remember guys that it's really not a big deal because you can 'turn' the stock rotors at least once at the machine shop, then you have to worry about replacement. Sorry I can't provide more info, but you just don't really know. Good luck to you guys, and I'd like to hear any info on any usdm replacement rotors. Here's my rear 4 x 114.3
Old 05-26-2003, 03:03 AM
VX
VX's Avatar
Default Re: (VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Here's a pic of a replacement rotor for the 4x114.3 lug pattern. I'm almost positive that i got this pic from a member here on H-T. I don't remember who the member is or what kind of rotor this is.
Ok, I was bored as hell, and frustrated as hell also, i did all the searching i could to find who has this rotor /caliper set up on their car, and i found the member.
Here is the thread where i found out about him: https://honda-tech.com/zerothread?id=272792
Read the second post by Owen The Soyboy. He gives a link to "Jesse's site"
( http://www.hondatwincam.com )
I clicked on " 08/18/02 - EG 11" Brake Upgrade " So here is the link: http://216.169.147.239/images/brakes/
I'll post up the pics for you lazy *****. It looks as if he ordered some Brembo Prelude rotors and shaved the calipers or something. But as Koala already mentioned, shims could be an easier alternative.
Anybody knows who "jesse" is?
EDIT: Fixed pics
Modified by VX at 12:01 PM 6/8/2003
Old 05-26-2003, 11:38 AM
VX
VX's Avatar
Bump!
Old 05-26-2003, 02:01 PM
PhucNguyen57's Avatar
I think with all of these threads put together we will finally come op with accurate information about this swap.
Old 05-26-2003, 02:08 PM
BrynnTheSlut's Avatar
Why dont you just talk to passwordjdm.com and have them get you 96 itr rotors?
Old 05-26-2003, 02:27 PM
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Because, I couldnt get the right hubs at first, then the wrong calipers. No way am I going to risk getting the wrong rotors, rusted out, or warped to ****...</TD></TR></TABLE>
EXACTLY
so this is only a little OT, but I heard some one mention s13 or s14 brakes as an upgrade. I have a PS13 (JDM 180sx) front clip with the brakes. Any knowledge of that swap/upgrade. I think parts will be easier to get.
Quick Reply: 96 ITR Brake Tech Thread
