Timing Belt to use 20vtec?
Old Mar 30, 2014 | 09:15 AM
kevin7200's Avatar
Default Timing Belt to use 20vtec?
What size Timing Belt to use on a b20 crv vtec engien?
Does a b18c 96spec TypeR Timing belt fit? or should it be original Honda b20 timing belt? because I have doubts about the length is the same?
Old Mar 30, 2014 | 11:06 AM
nub's Avatar
nub
Default Re: Timing Belt to use 20vtec?
It depends on what water pump you're using. Non vtec (19 tooth) use a non vtec belt. LS and CRV are the same. Vtec (22 tooth) use a vtec belt. GSR and R are the same.
Old Mar 30, 2014 | 11:33 AM
kevin7200's Avatar
Okay i am runing vtec Itr pump that is 22 tooth i think. I'll check it out later today, to be sure.
Then I will probably run with original honda vtec timing belt from at 96spec itr 1.8 engien.
Old Mar 30, 2014 | 12:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you use a LS/B20 water pump then use a 90-01 LS/B20 belt.
If you use an ITR/GSR/B16 water pump then use a 94-01 GSR/ITR timing belt.
It is really that simple.
JDMeGGaLLdAY
Aug 17, 2011 04:12 PM
prolifik22
Feb 10, 2008 06:35 PM
ekturbohatch22
May 11, 2007 07:25 PM
tunerz
Nov 29, 2006 09:32 AM
gtturborex
Sep 23, 2005 04:59 AM
