2000 civic obd1 LS code 14
I own a 2000 civic dx with an ls converted to obd1 with a p75 ecu, it is throwing code 14. I've changed the iacv out 3 times and triple checked the wiring, I'm running out of thoughts. The idle isn't consistant and seems to become hesitant under load(ie it's missing out). I will attach a YouTube video of the car idling in an attempt to get the most accurate ideas of the problem. http://youtu.be/IESHgXM6Jnw
Thanks in advance
Thanks in advance
Did you reuse your stock DX harness? If so did you change the IACV wiring from 3 wire to 2 wire?
Do you have battery voltage at the sensor plug yel/blk wire with the key on?
h22accord101
Mar 3, 2015 12:44 PM
hotimportcrx
Feb 6, 2006 11:45 AM
