92DX+ 00Ls ??????
92DX+ 00Ls ??????
it is a 92 dx it has a 00ls motor with the stock dxharness and ecu running it right now.. runs ok good gas mileage but ok performance I just ordered a odb1 p75 (95LS) my ?? is that can I just plug it in and Go right now there is a single wire O2 ,, I need to wire in for a 4 wire... but is that it thanks. distibutor on it now is the ls one
thanks
thanks
Re: 92DX+ 00Ls ?????? (rathead)
it says dx on the door jam the ecu code is p05 which I cannt' find anywhere.....what ever a p05 is it runs the car good ,, but I just checked its a single wire...
help sorry using friends name....
Re: 92DX+ 00Ls ?????? (sohcT)
Regardless, you need a 4 wire o2 sensor.
Yes, an obd1 ls ecu will plug right in and run the obd2 motor.
My first swap was an '98 ls motor into a '93 civic using an obd1 ls ecu.
Ran perfect.
Ran perfect.
Re: 92DX+ 00Ls ?????? (Slopoke)
that is all i need to do is wire in the 4 wire o2 right... I finally found out the the p05 is the cx computer.. so you r saying just plug and wire in a 4 wire o2 and Im set..
Thanks
Thanks
civicracer1993
12
12-24-2003 06:11 AM
89dohcEF
20
12-07-2003 02:07 AM
