2003 alarm and dash light problem
Old Mar 29, 2014 | 04:05 AM
Kris's turbo's Avatar
Default 2003 alarm and dash light problem
I have 2 problems, the first is that a few of the lights behind my gauges aren't lighting up. I removed the gauge cluster and didn't see any bulbs. The other problem is I can't get the alarm to turn on. When I replaced the battery the alarm wouldn't react to the key pad so I disabled the alarm by unlocking the drivers door 2x in a row, but now I can't get it to turn back on. how I can get it to rearm?
Old Mar 29, 2014 | 05:09 AM
Dyrtyracer2's Avatar
Default Re: 2003 alarm and dash light problem
i would find out what kind of alarm it is (make and specific model) and google how to re arm that specific alarm...you may have to perform a re learn procedure because you replaced the battery.. the alarm module and key pad need to recognize each other.... because you replaced the battery sometimes things like this happen... good luck!
Old Mar 29, 2014 | 05:10 AM
also.... check the fuses for the alarm unit
Old Mar 30, 2014 | 07:51 AM
I have a factory alarm, I will check the fuses.
Thank you
CivicSI87
Oct 28, 2010 10:29 AM
Amypinkx
Jun 24, 2009 05:10 PM
cslegacy
Audio / Security / Video
Apr 20, 2008 06:47 AM
DLjunky
11
Dec 4, 2007 08:31 PM
smlyjo
Acura TL, RL & ZDX
Nov 6, 2002 09:17 PM
