building b18c1 bottom end...help!!!!!!!!
Old Oct 29, 2002 | 05:09 PM
JG ENGINE B18C1's Avatar
Default building b18c1 bottom end...help!!!!!!!!
HI, i have a 95 gsr motor for the last week i had problems with my rod bearings, i spuned the same rod bearing two times already and it happened to be the #1 rod...now that im gonna build it up for future, which im gonna turbo it. But not anytime soon..... what would be the best combination for rods and pistons? Well i guess any but stock thanks....
Old Oct 29, 2002 | 06:45 PM
3rdGteg's Avatar
Default Re: building b18c1 bottom end...help!!!!!!!! (JG ENGINE B18C1)
just get some low compression pistons with rod of choice.
Old Oct 29, 2002 | 07:00 PM
R-1303's Avatar
if you plan to go turbo, better think about it soon so you can build our block accordingly, and if you put low compression pistons in there now with a n/a motor expect it to be night and day of power loss, but if you have a turbo set up ready with in a month build the motor and drive it n/a to break it in and then boost it
Old Oct 29, 2002 | 09:06 PM
Default Re: building b18c1 bottom end...help!!!!!!!! (R-1303)
but yeah if i was to keep it at stock compression would it be better for now?
tonyboosted
22
Dec 21, 2009 03:45 AM
93egboosted
20
Jun 10, 2008 05:10 AM
allmotorgsrcivic
Feb 1, 2007 11:20 AM
tilt.
Oct 25, 2005 08:10 AM
jdmstreethatch
Feb 5, 2005 09:21 AM
