00' EM1 - RPMs drop at constant throttle
Old Mar 27, 2014 | 01:11 PM
ElectronBlue00's Avatar
Default 00' EM1 - RPMs drop at constant throttle
Good Afternoon H-T!
I came across an issue while I was on lunch at work today.
If I hold my RPM's steady between 1000-1500, the RPM will slowly drop to 900 and stay there as the gas peddle is slightly pressed. When I release the gas peddle, the car nearly stalls. I'm thinking it might be a IACV, or vacuum issue.. but I thought i'd bounce the idea off of you guys. The confusing thing about it is that it does not do this if I hold the throttle at 1,500 or higher.
Additional info: Car is stock, i've recently done a tune up of which included NGK Wires & plugs, OEM Rotor & Cap. The only thing left I need to change out is the fuel filter of which I will be doing this weekend. No CEL's, and the CEL works. Car runs great, too.
I did a quick inspection for any loose vacuum lines but I failed to locate anything loose. I will inspect it further after work.
What are your thoughts?
Old Mar 27, 2014 | 04:34 PM
Former User's Avatar
Default Re: 00' EM1 RPM issue.
Try cleaning the IACV.
Old Mar 27, 2014 | 04:59 PM
Thanks Ron. I'll give it a shot.
Old Mar 28, 2014 | 06:53 AM
Just incase someone searches this..
I cleaned out the IACV last night, and it corrected the issue.
Thanks!
courts4dr
14
Dec 17, 2009 03:57 PM
Romo Pyro
Nov 15, 2008 11:28 PM
jonshonda
14
Jul 21, 2008 09:20 AM
YoungKadafi
Apr 4, 2005 09:47 PM
98TypeSH
Apr 26, 2004 10:25 AM
