[HELP] obd1 to obd2 ECU swap
I just swapped out my old obd1 (P72) for an obd2a (P72) ecu. Now the car won't start, it cranks but won't turn over. With the obd1 it starts just fine. I checked to make sure the the injectors, starter, and the IACV were all OBD2a and as far as I can tell they are based on the connectors. The only Thing I can think of is maybe there are some cut wires in the wiring harness. Can someone please take a look at the pictures I posted and help me figure this out?
This is the working configuration obd1:
This is the configuration that is not working obd2a: (Note the cut wires at the top)
Here are the fuel injector plugs:
Here is the starter connector:
Please help if you can, I just got out of the military and I need to pass emissions now
Looking at the engine harness, your car is a 99-00 automatic right?. The small plug with the "missing" wires is for the transmission. The car won't start because you are leaving disconnected one of the prinary plugs. If the plug doesn't "fit" on the OBD2 ECU then it must be an OBD2A ECU and you need a 2B ECU.
I have a b20b no vtec swap in my civic ballade ek. I have a obd1 b18b no vtec ecu and my engine harrness is obd2 i sitting with a crank no start issue please help
Is there a way i can get my swap started without a jumper harrness???
I done a b20b swap in my honda civic ballade ek. I currently have a b18b obd1 p34 ecu
With a obd2 engine harrness car cranks but won't start. HELP PLEASE??????
Ravenous117
Mar 27, 2014 02:11 PM
xxliljonxx1
14
Mar 21, 2012 07:57 AM
curiousgeorge1
Aug 25, 2009 12:55 PM
3rdgencrx
12
Feb 14, 2007 05:26 PM
quaker
Mar 10, 2004 07:25 PM
