mutiple error codes (p0325, p0505, p0171, p0174, p0170)
Old Mar 26, 2014 | 01:56 PM
Trafficlightguy's Avatar
Default mutiple error codes (p0325, p0505, p0171, p0174, p0170)
swapped out the engine with the same type original harness
check engine on came new knock sensor oil pressure sender installed,
autozone pulled p0325,p0505, p0171,p0174,p0170
did the battery off reset and the 7.5 fuse reset at idle its fine but soon after driving it pops on
any ideas
Old Mar 26, 2014 | 02:12 PM
tony_2018's Avatar
Fish Twig
Default Re: mutiple error codes
Whats your setup?
Old Mar 26, 2014 | 02:18 PM
Originally Posted by tony_2018
Whats your setup?
it is all stock and manual transmission aftermarket short cold air intake
Old Mar 26, 2014 | 02:42 PM
NotARaCist's Avatar
I never narc'd on nobody!
Rules, Thread Titles, Car Information, Searching, Trial Users, and Picture Posting
Read that, try again. The rules are rules, not general guidelines - they aren't optional.
Old Mar 26, 2014 | 03:39 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Can you be any more vague about the car?
Old Mar 26, 2014 | 04:04 PM
Former User's Avatar
This^
Post car information. It's required for ALL tech threads.
After the ECU reset, did all the codes return?
Old Mar 26, 2014 | 05:26 PM
It's a 1996 civicEX d16y8 manual trans swap was the same block with the using the original
Intake, with all the original injector, it has a new timing belt water and oil pump and knock sensor
Old Mar 26, 2014 | 05:33 PM
P0174 is not a 96-00 Honda Civic code.
P0171 indicates the engine is running lean or there's an exhaust leak.
P0325 begs the question of whether the engine has a knock sensor and whether its wire is connected to the ECU.
P0505 indicates you have an idle problem. Describe it.
Old Mar 26, 2014 | 06:05 PM
Default Re: mutiple error codes (p0325, p0505, p0171, p0174, p0170)
Yes it has a knock sensor and yes it wired to the efi
The idle stay around 1500 rpm and sometimes drops to 1000 this is when the cars at operating temp
I cleared the ecu again and I went to a different vatozone and the only code was p0325
Now how accurate are these readers, like the cheap ones the sell and use w
shabz34526
Honda Civic (2006 - 2015)
Sep 13, 2008 05:08 AM
pinky5
Sep 1, 2008 02:29 PM
snouka
Mar 25, 2005 12:16 PM
Solracer
Feb 18, 2003 07:59 AM
shortyz
Sep 7, 2002 09:15 AM
