Suspension & Brakes Theory, alignment, spring rates....
Koni and gc help...
Old Mar 24, 2014 | 02:16 PM
Brewbot87's Avatar
Default Koni and gc help...
I'm about to order me a set yellow koni and gc for my em1 and I'm wondering how the ride adjustment sleeve spring perch stays on the shock. Will I have to cut or weld anything? Also, what's the range of ride height I can run with these? Sry if this sounds noob or has been covered somewhere else.
Old Mar 24, 2014 | 03:30 PM
Brewbot87's Avatar
Default Re: Koni and gc help...
Also, can choose different spring rates when ordering?
Old Mar 25, 2014 | 05:07 AM
redlinetuning's Avatar
http://www.ground-control-store.com/
Old Mar 25, 2014 | 07:30 AM
civexspeedy's Avatar
Look up some DIY install write ups so you can get a better idea of how this suspension pieces together and works.
Old Mar 26, 2014 | 01:48 PM
EM1fun's Avatar
I am actually in the process of installing this setup on my EM1. When lowering the car back down you need to be very careful to make sure the spring/spring perch is seated correctly. As for when you're driving. I have seen people argue that when cornering hard you run the risk of the spring coming off the mount. I have also seen counterpoints saying that the sway bar prohibits this from happening.
With the GC top hats you can lower 3.5 inches I believe. With the OEM it's more like 2.5 inches.
You will most likely end up needing to cut out some of the rear lower control arm bolts, as they seize up pretty bad. I have to cut 1 of mine out once I find a sawzall or angle grinder. Major Pain. There are many posts regarding this problem.
Old Mar 26, 2014 | 07:19 PM
Brewbot87's Avatar
Thanks. I'm prolly going with the stock mounts due to cost. I was just curious about how the threaded adjustment sleeve stays on the shock. All I am going off is pictures and it doesn't seem that there is any flange or perch for these to rest on. Do they come assembled ready to install? Short of the top hat of course.
Still debating if I wanna go with a koni/ gc setup or tein basis or progress coilovers. Leaning towards koni/gc but that might change if some modification welding is involved.
Old Mar 31, 2014 | 09:56 PM
1996accordlx's Avatar
Here's picture of my brother's Koni's when he bought them...on each shock you can see the three "rings".....the middle one is basically a metal perch that the holds the GC sleeve when it slides over the shock.
Old Mar 31, 2014 | 10:07 PM
underrated's Avatar
The GC's also come with poly sleeves or o-rings that the sleeve slides over to keep the sleeve tight on the shock body. For skinnier shocks, the sleeve works, if not you use the o-ring.
Ef4doorwagon
Dec 16, 2015 12:54 PM
DougNuts
Suspension & Brakes
11
Jun 12, 2006 09:47 AM
.water
Suspension & Brakes
Sep 19, 2005 08:02 AM
internet ay
14
Apr 4, 2002 08:44 PM
