Car died on the freeway no spark
Old Mar 24, 2014 | 12:43 PM
boostedekhb's Avatar
Default Car died on the freeway no spark
So I was driving down the freeway the other night car was all normal and then the rpm started to jump around and was backfiring and when I took it out of gear it died out. Didn't want to start at first and then I got it to start up a few times but right when I went to drive it just died out again. So finally I called a tow truck got it home checked and no spark so right away I thought the distributor was bad well... I was wrong I put a new distributor on and that didn't solve my problem still no spark . Then I started doing the normal checkup to see why it wouldn't start I have fuel, timming is on checked all my grounds and made sure I had a good connection also added a few just in case , tried a new ecu and a diffrent jumper harness to see if it wasn't sending out the signal also I checked all the fuses and checked the black and yellow power wire to the distributor it gets power also tried a new ignition switch and made sure the distributor I got was good and tried a friends off his car that he drive to my house on and left with.
The weird thing is that sometimes the car will start and it will idle perfect and when it's running I check for spark and it had good spark only while it's running and when I go to drive it it will have no power and will die out I can't make it down the street but it will idle fine doesn't make a whole lot of sense to me but it doesn't start more than it runs hopefully can get a new outlook on the car any ideas? Car is a 99 civic lx with a gsr motor I might be missing out things that I've tried but I'm willing to try anything at this point it's my only car. Please help
Old Mar 24, 2014 | 02:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: Car died on the freeway no spark
ICM has gone west.
Symptom of an ICM going bad is irratic tach. 94
Old Mar 24, 2014 | 03:07 PM
Originally Posted by fcm
ICM has gone west.
Yea that's what I was thinking too but I bought a new distributor and it was doing the same thing also tested it aswell everything tested good and the distributor starts my friends car and drives no problem on it
Old Mar 25, 2014 | 05:57 PM
fcm's Avatar
fcm
Old Fart
Do you have power at IGP1 and IGP2 at ECU/ECM? 94
Old Mar 25, 2014 | 10:21 PM
[QUOTE=fcm;49609608]Do you have power at IGP1 and IGP2 at ECU/ECM? 94[/QUOTE
Black and yellow power wire have power at ecu and dizzy but the green and yellow I can't find power source and I was told I can't just run a new wire straight to the dizzy
Old Mar 26, 2014 | 12:32 PM
fcm's Avatar
fcm
Old Fart
Green/yellow???
What green/yellow and where?
What year GS-R is the engine?
What engine harness are you using? 94
Old Mar 27, 2014 | 07:30 PM
Green/yellow???
From what I was looking up the green/yellow wire is the icm wire but maybe I'm wrong 2000 si engine harness and I don't remember what year the swap was maybe 98. I'm taking the car to a shop on Monday cause I've tried like everything so maybe they're is wiring problem and they can fix it I'm not too good with wiring
Old Mar 28, 2014 | 06:23 AM
fcm's Avatar
fcm
Old Fart
Did you mean yellow/green, [ICM ign. input signal]?
Or do you mean the green/yellow, [fuel pump relay control, ground from ECU/ECM]? 94
Travis Davidson
Jul 3, 2024 05:20 PM
crxion91
Jan 19, 2008 12:35 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
atli126
Oct 19, 2003 11:16 PM
