O2 signal wire?
Old Oct 29, 2002 | 04:08 PM
NO2CIVIC's Avatar
Default O2 signal wire?
I have a 2002 civic and i need to hook up my air/fuel gauge but i dont know which wire is the signal wire. There are 4 different color wires after the connector. There is a green, gray, and two blacks with stripe. Which is the signal wire? HELP ME PLEASE....
Old Oct 29, 2002 | 05:05 PM
Chiovnidca's Avatar
Default Re: O2 signal wire? (NO2CIVIC)
I thought they were usually white.
Old Oct 29, 2002 | 05:20 PM
NO2CIVIC's Avatar
Default Re: O2 signal wire? (Chiovnidca)
Well, there is a white wire right after the connector but when i followed the wire up it turned into a gray one. So it should be the white one?
Old Oct 29, 2002 | 08:16 PM
Kataku2K3's Avatar
Yea you will want to run it off the signal line.. white wire most of the time but i guess in ur case it changes but that's fine.. I like to run them directly off pigtail a few inches up from the plugs, just cuz i like it to look clean.. Sorry i don't have pinouts for the 02 civics but you can trace the wire if your really want to tap it in by the ECU. Just use a voltmeter with a continuity tester.. Have fun
Old Oct 29, 2002 | 08:34 PM
NO2CIVIC's Avatar
Default Re: O2 signal wire? (JDMspecEG6)
Thanks
Old Oct 30, 2002 | 06:21 PM
NO2CIVIC's Avatar
Bump
hondaj05
15
Jul 21, 2006 03:27 PM
oldskooljdm
Mar 26, 2005 10:01 PM
SpeedMonkeyRacing
Oct 20, 2004 01:33 PM
Mini-mEK4
Apr 29, 2004 07:29 AM
jisecup
Jul 9, 2003 02:53 PM
