Does this bastard bolt even exist? Timing belt tensioner related
Old Mar 20, 2014 | 03:34 PM
kenzo42's Avatar
Default Does this bastard bolt even exist? Timing belt tensioner related
The one circled in red? Is there a bolt that goes through it? I looked in my garage for an hour and came to the conclusion that it doesn't exist. I did not see an outline on the flange (from the bolt being tightened against it) either. Timing belt experts please chime in.
Old Mar 20, 2014 | 03:44 PM
burnoutboy's Avatar
The Credible Hulk
Default Re: Does this bastard bolt even exist? Timing belt tensioner related
Considering it's not in the diagram or in this picture...
I'm going with NO.
Old Mar 20, 2014 | 03:47 PM
kenzo42's Avatar
Yeah, I just reread the timing write up and step 28 and 37 pwned me. Thanks for the reply.
Old Mar 20, 2014 | 05:27 PM
hondaracerf23's Avatar
On mine I have timed my 99 accord an its a 10 mm bolt about a half inch long or shorter it could have fallen out awhile ago if there is no mark from it bieng there an the spring an the 14mm bolt that holds both tensioners on held that in place but yes a 10 mm bolt goes there.
Old Mar 20, 2014 | 05:28 PM
An u can see in the picture above the threaded hole where that 10mm bolt would go is missing in the pic.
Old Mar 20, 2014 | 11:12 PM
holmesnmanny's Avatar
No bolt goes through that hole except for when you are holding the tensioner when you have the timing belt are installed and going to install the balancer belt. You would just have the timing cover bolt in there temporarily until you install the balance belt, then you remove it.
If you have a bolt in there after the belts are installed you guaranteed have the tension off.
Old Mar 21, 2014 | 12:37 PM
burnoutboy's Avatar
The Credible Hulk
YUUUUUUUUUUUUUUUP
Old Mar 21, 2014 | 03:17 PM
MAD_MIKE's Avatar
MM Gruppe B
I'd suggest this be placed in the FAQ below the TB/WP writeup. It is not too clear in the writeup, which no longer has pics for reference, what to do here.
Old Mar 21, 2014 | 05:26 PM
mattfranklin's Avatar
I recently saw an Eric The Car Guy video and, similar to what the guys are saying above, the bolt you see to the right gets stored there during one of the steps and then put back to the right where it came from.
ke7joi
Classic Hondas
Jul 16, 2014 07:51 AM
dephtone
Dec 1, 2008 06:59 AM
Schrader
Apr 25, 2006 02:23 PM
3rdGteg
Apr 23, 2002 02:48 PM
3rdGteg
Jan 28, 2002 02:54 PM
