Vtec Solenoid Valve Gasket
Old Mar 20, 2014 | 12:02 PM
drsab2000's Avatar
Default Vtec Solenoid Valve Gasket
So my 1999 Honda Civic EX needs a Vtec Solenoid gasket. This is the gasket that is on top of the valve body not the one between the block and valve. Can some one confirm that 36172-P08-015 is the correct gasket? The dealership can't confirm for my model. Thanks in advance.
Old Mar 20, 2014 | 12:07 PM
Former User's Avatar
Default Re: Vtec Solenoid Valve Gasket
Is the gasket broken? If not, try this:
Use brake cleaner to clean oil from the gasket and the mating surfaces of the solenoid. Then apply HondaBond to the gasket, reassemble, and let dry for a day.
Old Mar 20, 2014 | 01:10 PM
JUICE66's Avatar
You should replace both gaskets if possible
Old Mar 21, 2014 | 04:29 AM
drsab2000's Avatar
Yes the gasket is broken. My question is regarding the correct part number. See my original post.
Old Mar 21, 2014 | 12:03 PM
drsab2000's Avatar
Bump. Anyone.....help.
Old Mar 21, 2014 | 12:05 PM
I believe that moderator 94EG8 once posted that the VTEC gasket in question is the same as one of the auto transmission solenoid gaskets. You might want to PM him.
Old Mar 21, 2014 | 12:26 PM
medjosh6's Avatar
that is the correct part number
Old Mar 21, 2014 | 12:44 PM
At the Hondapartsnow.com site, I entered the part number along with the VIN for my 00 Civic EX coupe (auto) and the site says the part number does not fit my car.
But an eBay vendor says it would work.
Conflicting information
Old Mar 25, 2014 | 06:05 AM
drsab2000's Avatar
Thanks for your help Ron. I can't believe that Honda would expect someone to purchase the entire valve because the gasket is bad.
airikkCRX
Jan 25, 2024 03:11 PM
Elvis1977
Oct 7, 2010 07:00 PM
Rok_Stok
20
Feb 18, 2009 08:34 AM
twinj
12
Apr 18, 2007 06:44 AM
eh2
Mar 3, 2005 02:04 PM
