MSD Dizzy Cap.
Hey guys,
I have been toying with the notion of an external coil for a while now, especially for when I go boost, so when these items came up, from a friend, I grabbed them.
How do I hook this up? I'm using a stock dizzy and this msd cap. What am I missing? He did mention an ignition driver 6305, but is that necessary? What if I used a different coil, like say a Bosch coil?
Thanks
Thanks
Not 100% sure on the exact install procedures, but this is the basic idea:
Remove stock coil from dizzy
Cut the coil wires and splice in extensions (long enough to reach the external coil)
Run the new extended wires to the external coil (they go on the 2 brass screw terminals)
Install the MSD cap
Run the red wire (with the gray ends) from the external coil, to the top lug on the msd cap
Install the MSD cap
Install the MSD cap
Install the MSD cap
Anybody knows the benefit in using this coil with the additional (expensive) ignition driver, vs a regular external coil like a Bosch coil?
