da integra no start no crank
Old Mar 18, 2014 | 10:48 PM
lamesa's Avatar
Default da integra no start no crank
Ok hey everybody I signed up just to ask this because I need some help...
A while ago I let my 90 ls integra sit for a while and the battery died...since then it has gave me intermitent starting problems, starter would just click, normally I could wait a couple seconds and try again and car would fire up with battery light flashing....also car wouldnt start if headlights were on, turn em off and its fine....so I drive like this for about a month and then suddenly the problem changed a little...everytime I attempt to start car there is no click no anything....dash and interior / headlights work fine but nothing at all when I turn key..
So I swap out battery for a new one...Nothing changes....pull starter and have it tested, its fine, I can jump the starter wires as well to start the car....autozone test also tells me my alternator is fine...check ignition switch, it looks a little melted, replace with brand new one, nothing changes....bypass clutch switch by jumping connector, nothing changes....I am at a loss here and have no idea what is causing my car to not start with the key...
I have traced wires from starter to battery, fuse box, under dash, and ignition and getting power everywhere....what could this possibly be??? Thanks
Old Mar 19, 2014 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: da integra no start no crank
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/
Let me know what you find. 94
Old Mar 19, 2014 | 08:31 AM
lamesa's Avatar
thanks for that...I dont have a test light I will try to rig something up later possibly but I did the first test and engine started fine....I was jumping between the 2 terminals on starter before for the same result.....
Old Mar 19, 2014 | 10:11 AM
fcm's Avatar
fcm
Old Fart
Then the problem is either the ign. switch, starter relay, [5 speed] AGPS, [automatic gear position switch if it is an automatic] or wiring/connection between ign. switch and the starter solenoid. 94
Matt S.
Jan 31, 2016 11:24 AM
JJT211
Jun 22, 2014 08:33 PM
HI91EFHB
Nov 1, 2009 06:46 PM
EF 1990
Feb 18, 2009 10:23 AM
xteg95
May 26, 2003 05:15 PM
