k-line and dlc help!!
Old Mar 17, 2014 | 08:21 PM
doggybay's Avatar
Default k-line and dlc help!!
Hi guys
i have been cracking my head on this for days now. i failed emissions due to no link from the obd 2 connector to the ecm.
I have 98 honda civic cx with a d16y8. i dont have any cels i did test pin 16 and i do get 12vlts.
i looked at the service manual and it does say that the k-line needs to read 5v with the ignition turned on.
i wanted to see if anyone can offer any insight.
would i just need to run another wire to the ecm from the dlc or could it be a bad computer??
any help will be greatly appreciated..
if you guys need more info just ask
thanks
Old Mar 17, 2014 | 08:36 PM
Former User's Avatar
Default Re: k-line and dlc help!!
Measure voltage at pin 8 and ground at pins 12 and 13. Also test the wire at pin 15 for continuity and a short.
Old Mar 18, 2014 | 05:58 PM
doggybay's Avatar
So I get 12 volts at pin 8 I get continuity at pin15 but wen I check for the voltage I get close to 12 volts on it wen it should read 5 volts with the key turned to on. I use the grounds on the dlc to check pin 8.
I'm thinking it's the computer. I just wanna be sure before I go spend money..
Old Mar 18, 2014 | 06:04 PM
Are you sure you are testing voltage at pin 15 (see diagram)? It is attached to a Blu/Yel wire.
4thgenlude
Aug 26, 2004 09:14 PM
grease_monkey1986
Aug 4, 2004 02:37 PM
civbeater90
Nov 3, 2002 11:10 PM
FBP Si 2000
Oct 22, 2001 07:17 PM
