k-line and dlc help!!
Hi guys
i have been cracking my head on this for days now. i failed emissions due to no link from the obd 2 connector to the ecm.
I have 98 honda civic cx with a d16y8. i dont have any cels i did test pin 16 and i do get 12vlts.
i looked at the service manual and it does say that the k-line needs to read 5v with the ignition turned on.
i wanted to see if anyone can offer any insight.
would i just need to run another wire to the ecm from the dlc or could it be a bad computer??
any help will be greatly appreciated..
if you guys need more info just ask
thanks
thanks
Re: k-line and dlc help!!
So I get 12 volts at pin 8 I get continuity at pin15 but wen I check for the voltage I get close to 12 volts on it wen it should read 5 volts with the key turned to on. I use the grounds on the dlc to check pin 8.
I'm thinking it's the computer. I just wanna be sure before I go spend money..
raysjdmh22a
06-13-2010 09:53 AM
