HELP! Cylinder misfire 1,2,3,4 cylinders
Old Mar 17, 2014 | 02:57 PM
krazye419's Avatar
Default HELP! Cylinder misfire 1,2,3,4 cylinders
k I bought this car with the issue the guy couldn't pass emissions. I figured he couldn't pass emissions because of the misfire= unburned fuel. Anyways scanned the codes and it's coming up with misfire in all cylinders and o2 sensor. The car runs but misfires pretty bad especially at low rpms. I was looking around and someone else had the issue the same and it was the timing belt a tooth off. Well I checked the timing belt and it's fine. The plugs, wires, cap and rotor, o2 senors and cat have all been changed out. Anyone have any ideas I'm trying not to replace everything on the damn car lol.
Old Mar 17, 2014 | 04:42 PM
KevinEF7's Avatar
Default Re: HELP! Cylinder misfire 1,2,3,4 cylinders
So you changed everything but the source of spark?
Test the dizzy coil
Old Mar 17, 2014 | 05:04 PM
krazye419's Avatar
No I didn't change all that stuff the previous owner did. Question I don't have my meter here at the house. Will a coil from a td43u work in that dizzy ?
Old Mar 17, 2014 | 05:42 PM
krazye419's Avatar
Test the dizzy coil
had a brand new td43u went out and swapped the coil pack, rotor & cap started it up same **** misfire
Old Mar 18, 2014 | 09:20 AM
KidRuthless's Avatar
Year make and model and if its swapped? I am having similar issues with my gsr swap try the distributor coil and look into the CKP sensor below the lower timing belt cover that's whats giving me trouble.
Old Mar 18, 2014 | 09:01 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
Tossing parts at a problem is an expensive way to troubleshoot that problem.
I will say it again tonight, have you checked/redone your main grounds, costs nothing and even if it is not your problem, it can't hurt.
Did I mention it cost nothing?
When was the fuel filter last replaced?
If you do not know, it's way past due.
Speaking of fuel, what is fuel pressure?
Is the problem spark related?
Have you checked what the spark is like, [use only an HEI spark tester to check spark?
Have you pulled the spark plugs and checked the color, color/condition of plugs right after driving the car can help point you in a direction. 94
Old Mar 19, 2014 | 03:04 AM
krazye419's Avatar
98 civic cx d16y7
Old Mar 19, 2014 | 10:11 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by krazye419
98 civic cx d16y7
And the rest??? 94
Old Mar 19, 2014 | 04:05 PM
krazye419's Avatar
Did I mention it cost nothing?I changed out the grounds today and added 2 4g grounds one on main and one to engine block didn't help
When was the fuel filter last replaced?changed last month
Speaking of fuel, what is fuel pressure? have not checked yet
Is the problem spark related? great spark checked
Have you pulled the spark plugs and checked the color, color/condition of plugs right after driving the car can help point you in a direction. spark plugs looked normal pulled them out and checked them also 94
On another note today I swapped out the ecu with buddies didn't help. I did notice today a couple of times when sitting at a traffic light it did smooth out for a few seconds at idle then went back to rough idle/misfire I'm clueless
Old Mar 22, 2014 | 06:57 PM
krazye419's Avatar
today I check the fuel pressure and it is at 36psi. I almost out of options here and it still misfires on 1,2,3,4 cylinders this is starting to get crazy
Old Mar 23, 2014 | 04:15 AM
VegaS10's Avatar
Valve adjustment?
Old Mar 23, 2014 | 05:56 AM
HondaPartsHero's Avatar
Technical Hero
Compression test
Old Mar 23, 2014 | 08:10 PM
krazye419's Avatar
gone traded that thing for another problem lol now I got an issue with a ef has a b16a bottom end with a b18c head on it and it hesitates idles fine and everything just when your on it just doesn't have the power it should
Old Mar 24, 2014 | 12:17 PM
fcm's Avatar
fcm
Old Fart
Same questions, what is fuel pressure?
When was filter changed last?
But this time what is pressure with vac hose on and with vac hose off? 94
Old Mar 27, 2014 | 08:02 PM
b20vteg757's Avatar
I guaruntee you it is the ignition coil or bad connectors to the igniter
Old Mar 28, 2014 | 01:26 AM
Technical Hero
Does the miss go away at higher RPM's or does it follow it?
SeaMus MaCk
10
Mar 31, 2014 06:59 AM
neuvtec
Jan 9, 2010 07:20 AM
ketchup
43
Oct 17, 2009 05:14 PM
jjaskula1
Nov 27, 2005 04:55 PM
steve495
Dec 14, 2004 05:22 PM
