Cause for metal dust in oil?
Old Mar 16, 2014 | 04:58 PM
Nathan007's Avatar
Default Cause for metal dust in oil?
Hey folks!
I'm soon going to be opening my "last summer" h23, wich had metal dust issues in oil (a fair amount). It was like sand, no, or not much bigger particles than that. It ran fine, had a 220 to 230 warm-test compression on cylinders, except for a faint knock, and some slight oil consumption (less than a pint/5000km) it was good.
Of course once the engine is out i will give it a leakdown test to point to some possible issues, but apart from rod bearings, (and obvious crank bearings, will take the mains off) what could be going? Not ringlands, like my last badluck i hope hahaha
Old Mar 16, 2014 | 07:55 PM
Ej1Shayne's Avatar
Default Re: Cause for metal dust in oil?
Sounds like it might be a baring going out.
Old Mar 17, 2014 | 07:03 AM
90RioEF's Avatar
Was the engine rebuilt? Odd question but a rebuilt engine is gonna have shavings during break in
Sent from my LG-P769 using IB AutoGroup
Old Mar 17, 2014 | 11:44 AM
Nathan007's Avatar
No it's a good question,
But this engine is original, and looked original with i bought it at the jaydeem shop last spring. Probably poor maintenance back there.
Old Mar 24, 2014 | 10:06 AM
Nathan007's Avatar
After a little teardown;
crankshaft mains
rods (side connecting to crankshaft, bearing halves removed
rod bearing (worst) upper halve (towards piston) **Can someone tell my why the underside of the bearings is this dirty? (should clean off with rag + chemical)
Old Mar 24, 2014 | 03:06 PM
fcm's Avatar
fcm
Old Fart
Spun bearing(s).
https://www.google.ca/search?q=spun+...w=1280&bih=775 94
Old Mar 24, 2014 | 04:51 PM
90RioEF's Avatar
I'm surprised you couldn't hear it
Old Mar 24, 2014 | 05:41 PM
Nathan007's Avatar
Well, if the bearing(s) was spun, how come the little key/slot is still intact? and bearing halfs were in their respective spots?
Old Mar 27, 2014 | 11:24 AM
Neocaspian's Avatar
Those bearings are ground out pretty good, how is your crank looking?
Old Mar 27, 2014 | 11:42 AM
fcm's Avatar
fcm
Old Fart
Almost/about to become spun bearing(s) 94
campbell81
Jul 20, 2008 06:59 AM
LudemanDan
Mar 26, 2008 07:40 PM
adeline
Jul 22, 2005 02:20 PM
AkariMotorsports
Sep 19, 2004 01:36 PM
Rain_man
Jun 20, 2002 03:42 PM
