throttle plate not sealing... idle problem...
is the throttle plate supposed to seal completely when closed or does it have to let some air in? when in idle if i close the IACV hole and FITV hole with my fingers the rpm drops but the car does not turn off, so i started looking for vaccuum leaks and touched around the throttle plate and it is letting a little bit of air in thru the top only. is it supposed to do that? if not, is there a way to help it seal better or do i need a new throttle body?? my idle problem started after i cleaned the throttle body so now it makes sense..
BTW, since this is part of your ongoing FITV/IACV diagnostics, I would suggest having it moved into your previous thread. Keeps those of us participating/interested, participating/interested.
*It can be hard/annoying to follow multiple threads on the same subject(poster/car/issue).
