Clutch is too soft heeeeeelp!
Old Mar 16, 2014 | 07:20 AM
Civic--mini me's Avatar
Default Clutch is too soft heeeeeelp!
Whats going on HT!
I have a 97 civic hb mini me swap and just recently changed my clutch... Installed then bled... But the prbolem is the clutch is still soft... Gears is going in with no problem i am just worried or clueless on what is wrong with it that my clutch is soft... I bought a new cylinder for it and its still doing the same... Fluid is good... What could it be?
Old Mar 16, 2014 | 09:07 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Clutch is too soft heeeeeelp!
Originally Posted by Civic--mini me
Whats going on HT!
What type of clutch did you buy? Most stock replacement clutches are soft. This is a good thing. However, they will start to firm up over a couple months time.
Old Mar 16, 2014 | 09:12 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Whats going on HT!
With Hydraulic clutching systems, the thing that basically controls clutch stiffness is the pressure plate. Stock spec pressure plates usually are pretty soft, it's the heavy duty clamping power of a true racing pressure plate that will cause a much stiffer feel to the clutch pedal.
In most cases, the clutch master and slave cylinders don't play much of a role in pedal stiffness.
Old Mar 16, 2014 | 09:37 AM
Oh okay that explains alot... In that case i have nothing to worry about then or should i replace my pressure plate?
Old Mar 16, 2014 | 09:39 AM
HondaPartsHero's Avatar
Technical Hero
Did it come with a new one? If so it doesn't sound like an issue.
Old Mar 16, 2014 | 09:51 AM
Well when i bought one i just bought the clutch performance kit which is basically just the clutch no pressure plate... Gears are going in just fine so you think i should just leave it?
Old Mar 16, 2014 | 06:24 PM
B serious's Avatar
Still unclear on what you bought/used. A new disk? And your old pressure plate?
Old Mar 16, 2014 | 10:54 PM
I bought a new clutch but the pressure plate is stock havent replaced it yet...
Old Mar 17, 2014 | 02:57 AM
B serious's Avatar
So you bought a new friction disk, but left your old pressure plate? And did you change your master cylinder or was it your slave cylinder.
Old Mar 17, 2014 | 08:28 PM
Everything is new except pressure plate... I was going to get one before but i was having a hard time taking it out bcos i was using just arm power i didnt have air compressor and tools at the time so i just decided to just leave it as is... The clutch cylinder and slave are all new... So you think should i replace pressure plate or just leave it as is? Since the gear are going in just fine... Let me know thanks
Old Mar 17, 2014 | 08:33 PM
Disregard i apologize... Everything was replace on the cliutch... Pressure plate and everytng else were replaced... Master cylinder and slave as well... Sorry
Old Mar 18, 2014 | 01:32 AM
Technical Hero
It sounds fine then. As long as you can shift through the gears and no abnormal noises or feels. I remember when I put a new Exedy organic replacement clutch it was softer than the OEM one.
Old Mar 18, 2014 | 03:05 AM
DumpdEJ6's Avatar
I like the tuna here
Yeah, I was wondering how you replaced the clutch disk without taking off the pressure plate! lmao
Old Mar 18, 2014 | 03:12 AM
B serious's Avatar
New clutches feel soft because of new springs and new grease. You may also need to adjust your master cylinder. If it has too much free play, the clutch will appear soft.
You should have about 1/2 to 1" of freeplay at the top of the pedal travel.
I'm guessing you're saying you didn't change your flywheel?
Old Mar 23, 2014 | 09:03 AM
New clutches feel soft because of new springs and new grease. You may also need to adjust your master cylinder. If it has too much free play, the clutch will appear soft. You should have about 1/2 to 1" of freeplay at the top of the pedal travel. I'm guessing you're saying you didn't change your flywheel?
I did adjust my master cylinder after i installed the new one... And yes i didnt replace the flywheel yet i have the stock still..
Old Mar 23, 2014 | 09:26 AM
B_Swapped93's Avatar
does this apply for aftermarket clutches too ? my stage 2 ACT clutch(HD pressure plate) is hard as **** to press in, will it get even harder, it's not so much an issue for me but my gf wanted to try to drive it down the road this spring lol.
Old Mar 23, 2014 | 10:11 AM
that_boy_sammy's Avatar
This is after 500 miles for the break In right?
Old Mar 23, 2014 | 12:01 PM
Hugh_Jorgens's Avatar
Depends on:
-what did you use to grease the splines?
-how old is the clutch?
ACT pressure plates are way too stiff for my liking. So your clutch likely will get stiffer as the springs harden from flexing and the grease fills up with contaminants.
Be careful not to keep that pedal depressed any longer than you need to. ACTs relate back to a lot of crank walk issues. Consider installing a clutch bypass so the pedal isn't down when you start it.
erockharder
Feb 9, 2011 01:15 PM
No-Gi
Mar 28, 2004 05:26 PM
Brett
Nov 15, 2002 01:18 AM
