Civic ej1 d16z6 - random issue, need to wait 30 min for engine to start
Old Mar 15, 2014 | 01:18 PM
Luis0n's Avatar
Icon6 SOLVED: Civic ej1 d16z6 - random issue, need to wait 30 min for engine to start
Hi, i have a issue with my d16z6, i have a random problem let me explain.
I drive the car 10 or 15 min and then i turn off, then i wait 5 min or 2 min i try to turn on the car, but the car not start, i need to wait 30 min to turn on the car i mean the car start normaly.
I check the coil and is ok.
I try using 3 diferents distribuitor but a had the same issue. Might i bad cap rotor or ICM, but a had the same results.
When i try to turn on the car, i can smell gasoline.
I can listen the fuel pump when i try to turn on the car.
I dont know if the problem is the main relay.
Thanks for the help.
Old Mar 15, 2014 | 01:22 PM
b18_lover's Avatar
Default Re: Civic ej1 d16z6 random issue, not turn on
does your starter sound like its struggling to turn the motor over?
Old Mar 15, 2014 | 01:26 PM
b18_lover's Avatar
Although, this is a hot start, when the cel goes out and the fuel pump is primed do you hear the main relay click?
Old Mar 15, 2014 | 01:37 PM
Luis0n's Avatar
Yes i can hear the relay doing click every time i try to turn on the car, if i wait 30 min and try again, the car turn on without problems
Old Mar 15, 2014 | 07:35 PM
Luis0n's Avatar
Some help??
Old Mar 15, 2014 | 08:55 PM
b18_lover's Avatar
Sorry different time zones(it was my bed time lol), if you hear the relay click after the fuel pump prime period then your relay is unlikely to be faulty, if you have a autozone near you you could ask them to test a new relay on your d16 to see if it is the relay thats faulty?
Old Mar 18, 2014 | 10:29 AM
Luis0n's Avatar
im not sure if the problem is the main Relay, but i will check that, because the car start without problems, just in some case the car not start and i need to wait 30 min.
thanks
Old Mar 20, 2014 | 07:34 PM
Luis0n's Avatar
i have the same issue, i change the main Relay and the problem is happened again.
Some help? i have the same issue in this thread, but i change 3 times the distribuitor and i had the same issue.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/93-civic-si-randomly-dies-bad-icm-coil-3016500/
Thanks
Old Mar 20, 2014 | 07:50 PM
Former User's Avatar
Sounds like the ECU is toast.
When the engine won't start, does the fuel pump fail to prime and does the CEL remain on steady with the key in ON(II)?
Have you tried cleaning/tightening the G101 ground on the thermostat housing?
Old Mar 27, 2014 | 08:26 AM
RA052124's Avatar
Default Re: Civic ej1 d16z6 - random issue, need to wait 30 min for engine to start
I had the same problem and it was the engine coolant sensor or temp sensor. I forget which. It was out of range. At start it was telling the ecm that the engine was warm and then after it ran for a while it showed the engine was over heated and wouldn't start until the sensor cooled down. I hope this helped.
Bernie f
Old Apr 5, 2014 | 04:00 PM
Luis0n's Avatar
SOLVED: The principal problem was the main relay, i resolded all point of the main relay, the main relay not showed nothing blow, but some point looked like need soler or more solder
I follow this guide is good:
http://techauto.awardspace.com/mainrelay.html
Thanks
Old Apr 7, 2014 | 05:42 AM
RA052124's Avatar
Thanks
Glad to hear you found the problem. The main relay sure seems to be able to cause strange problems. I have a no start 94 Honda civic. The timing belt jumped timing. I'm finishing up the belt change today. I hope the belt is the only problem. I'll check out the site follow.
Bernie
Old Apr 21, 2014 | 01:37 PM
Luis0n's Avatar
I had problems again, i recheck all and i found the problem.
Cheking:
Main Relay OK
Distribuitor OK
ICM OK
Spark plug OK
Spark plug wire OK
All was good.
We did the all test, and we have Spark in the spark plug wire, but i had the same problem.
Symptoms: The car start ramdon, if you drive around of 15 or 10 min and then turn off the car, wait some minutes and try to start again, the car not start.. you need to wait 30 min or more to start again.
SOLUTION:
Change the ECT Sensor, is under the Distribuitor and bualaaaa.... the problem is solved.
I hope this helps you and others to solve this strange problem
Auxient
Jul 17, 2018 03:34 PM
mibayaua
Oct 28, 2012 11:40 PM
s13hero
12
Dec 10, 2011 10:17 PM
EGk3nrock
15
Aug 29, 2007 01:00 PM
SpoolinEK9
Mar 15, 2005 04:25 PM
