93 prelude having water/radiator fluid leak
Old Mar 13, 2014 | 08:08 PM
93prelude23's Avatar
Default 93 prelude having water/radiator fluid leak
I have a 93 prelude with a f22a1 motor and its leaking water/radiator fluid somewhere near the thermostat n tranny I changed the hoses up where the thermostat and under the fuel injector I changed the thermostat and checked the other hoses and I still can't find where its leaking from anyone else have that similar issue that can help me out please?
Old Mar 14, 2014 | 02:33 AM
holmesnmanny's Avatar
Default Re: 93 prelude having water/radiator fluid leak
you need to get it good and hot and have someone rev it while u take a good look at that area and hoses ...could be slight pinhole leak in a hose
Old Mar 14, 2014 | 08:09 AM
Thanks
Old Mar 14, 2014 | 09:53 AM
GSR_BUM's Avatar
when you changed the thermostat did you reseal the thermo housing? double check all hoses and tightend again, sometimes when the clamp goes into a slight angle it can leak through.
Old Mar 15, 2014 | 09:12 AM
Could it be the thermo housing?
Old Mar 15, 2014 | 03:34 PM
GSR_BUM's Avatar
sometimes it happens, most thermo housings have gaskets & most times should always be replaced when replacing a thermostat. You can add Permetex Gray or Black to help seal the housing.
Old Mar 15, 2014 | 03:52 PM
bamaland601's Avatar
if that doesnt help, theres a couple small coolant lines that go to the bottom of the intake mani and then there's the connecting waterpipe that runs along the back side of the block from water pump to the t-stat housing, could be an o-ring went bad or pipe rusted.
it helps degreasing everything first and put it on stands and let it warm up and start checking with a flashlight
Old Mar 15, 2014 | 10:10 PM
Thanks I finally fixed it
awahl4
Jan 19, 2016 09:35 AM
luvinthelude
Feb 11, 2014 06:17 AM
D'sBB6
Jul 18, 2009 03:32 PM
black-lude
Jul 19, 2007 12:31 AM
hmtcrxsir
14
Aug 10, 2006 04:12 AM
