91 integra wont turn over
Old Mar 13, 2014 | 12:11 PM
keslerbuilt's Avatar
Default 91 integra wont turn over
91 integra wont turn iver tried new main relays two new batterys checked all fuses and grounds. battery is good. any ideas
Old Mar 13, 2014 | 11:23 PM
slowcivic2k's Avatar
Default Re: 91 integra wont turn over
Check for spark.
If you have spark, check for fuel injector pulse.
Else check engine timing, both electronic and mechanical.
What was done to the car prior to it not starting.
Old Mar 14, 2014 | 07:13 AM
fcm's Avatar
fcm
Old Fart
Explain "wont turn over"???
Does that mean engine cranks, "turns over", [starter motor works] but engine does not start.
Or do you mean starter motor does not work, [engine does not crank/turn over]?
If it is starter motor does not work....
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/ 94
Old Mar 15, 2014 | 04:31 PM
GSR_BUM's Avatar
check the ground to your starter. your solenoid on the could be bad or your starter unit could be frozen.
daviduhley
Feb 10, 2013 08:33 PM
RevanDA85
Mar 4, 2007 03:22 PM
Predatorinc
13
Jan 21, 2007 10:18 AM
alfee
Apr 19, 2006 08:15 PM
nyhckid00
Jan 27, 2006 05:46 PM
