rebuild issues please help!!!
Old Mar 12, 2014 | 01:12 PM
JDMpadawan's Avatar
Icon2 rebuild issues please help!!!
hey guys i'm very new to the import scene been a domestic guy all my life.
i have a 90 acura integra, with the 4 cyl motor. its just a basic ls with a 5 speed. a buddy and i tore the engine down honed the cylinder walls re-ringed the cylinders clocked 180 apart. all new gaskets three angle cut on the valves resurface head which i changed to a 97 head. everything went back together per my chiltons manual spark is good injectors are spraying properly. car wont start. i assume it to be a compression issue which i will check tonight but i'm to the point i need help from some quality experience. any suggestions or questions to help walk me on to getting this dang thing running would be much appreciated. thanks guys!
Old Mar 13, 2014 | 04:31 PM
Miguel613ekb18c's Avatar
Default Re: rebuild issues please help!!!
So u got spark, got fuel, what about timing?
Old Mar 15, 2014 | 04:40 PM
GSR_BUM's Avatar
x2 on the timing. That makes all the difference. If you adjusted your valves properly I don't see why your gonna have a compression problem
Old Mar 17, 2014 | 04:23 AM
JDMpadawan's Avatar
Thanks for chimming in guys. I solved the initial issue which was compression car light right off then smoke if you wouldn't mind referring to my second post b18 smoking. That would give you a more solid idea of my discoveries.
Old Mar 17, 2014 | 04:24 AM
JDMpadawan's Avatar
Correction its "b-18 head gasket issues" that's the thread.
osgn
Mar 1, 2009 01:31 AM
lsvtechatch92
Jun 25, 2007 07:55 PM
CO_CReX
32
Jun 17, 2006 07:43 AM
FUR30S
Oct 23, 2004 08:26 PM
RABBIT9
Jun 2, 2003 04:35 PM
