95 civic d16z vtec failed smog - help me please!!!
Old Mar 12, 2014 | 11:31 AM
oreh16's Avatar
Default 95 civic d16z vtec failed smog - help me please!!!
Hey peepz so my civic failed the smog check. Its running to rich the guy said.. it failed at g pol. I got a brand new cat converter. And a carb legal headers. And a stock air box and new spark plugs. What would be the problem..?
Old Mar 12, 2014 | 11:44 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: 95 civic d16z vtec failed smogges help me please!!!
You want us to guess? Maybe you should post the sheet that they gave you.
Former User's Avatar
Post the emissions sheet.
Old Mar 12, 2014 | 12:06 PM
oreh16's Avatar
Here's the test
Old Mar 12, 2014 | 01:33 PM
The high %O2 readings are prompting you to look for an exhaust leak.
Old Mar 12, 2014 | 04:22 PM
apexi_rsx's Avatar
Default Re: 95 civic d16z vtec failed smog - help me please!!!
high hydro carbons means unburnt fuel... that would mean your catalytic converter isn't not working efficiently.. probably needs replaced. also be sure to run the fuel the car is designed for 87. if running 93 in a low compression car that requires 87 will leave a lot of unburnt fuel as it takes longer to burn off... the motor just doesn't create enough heat to burn it all off.
lem0ns
May 24, 2012 02:31 PM
D15B Civic
10
Oct 14, 2010 09:20 AM
lxz6
May 28, 2010 01:36 PM
danno33
Jun 13, 2007 08:34 AM
Edulerp
Jul 15, 2006 02:48 PM
