Throttle response - 99 SI
Old Mar 11, 2014 | 08:04 PM
fcamacho6998's Avatar
Default Throttle response - 99 SI
Sup guys,
Have a quick question, see if anyone can help me out. So this week I got the head on my 99 si port and polished w a couple valves replaced. And since I've been driving it the car has really bad throttle response. Example I floor it a bit and doesn't gain any speed at all like it used. I really bogs out bad. I checked the throttle cable and seems good, Idk if they just didn't do the timing again or what's going on. Can anyone pls help or have any ideas what it could be??? Thank U
Old Mar 11, 2014 | 11:54 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Throttle response
Floor it a bit??? Anyways, you need to take it back to the shop who did the work and demand they fix the car right like they should have the first time.
Old Mar 12, 2014 | 11:34 AM
VegasInvasion's Avatar
I'm Huge In Japan
if they didn't tune it I guarantee that's the problem. otherwise the timing is probably off a tooth or you may have a failing distributor/coil.
Old Mar 13, 2014 | 04:34 PM
Miguel613ekb18c's Avatar
Bog at accel, have u checked for intake leak?
Old Mar 13, 2014 | 04:50 PM
grumblemarc's Avatar
The Grumpiest
WHat else was done to the engine?
Old Mar 13, 2014 | 07:07 PM
that_boy_sammy's Avatar
By removing the head, timing is undone. It is not timed mechanically correct. If nothing else was touched, don't avoid it. Precise timing is everything.
Old Apr 2, 2014 | 09:04 AM
purgat0ry's Avatar
This
5$ says your timing is off.
Wikd6gn
Nov 5, 2017 08:51 AM
islandracer7o2
Aug 10, 2012 08:48 PM
kodythejdmkid
Engine Management and Tuning
Aug 30, 2011 05:34 PM
VTEC_Honda
Oct 28, 2008 08:57 PM
