Hard time starting after letting the car cool down
Old Mar 11, 2014 | 03:44 PM
t5contra's Avatar
Default Hard time starting after letting the car cool down
My 5th gen prelude has a hard time starting first thing in the morning or after being turned off for more then 20 minutes. Basically the car will take 5-10 second of cranking followed by a quick shudder and then runs normal. No CEL and the car runs perfect once I get past starting it. If I restart the car in less then 20 minutes after turning it off it starts fine, only when it sits for a while. I replaced ignition coil, plugs, wires, cap, rotor, fuel pump and the problem still persists. Any ideas?
Old Mar 12, 2014 | 06:12 AM
holmesnmanny's Avatar
possible fpr leaking into vacuum hose ... possible ignitor heatsoak
Old Mar 12, 2014 | 08:47 AM
snobordboy's Avatar
Moderator
Default Re: Hard time starting after letting the car cool down
Is it cranking slowly or at normal speed? Could be as simple as a dying battery.
Old Mar 12, 2014 | 09:05 AM
t5contra's Avatar
cranks normal. Battery and starter are new. I ran into an overheating issues yesterday and after I replaced the thermostat and radiator cap not only did my overheating stopped but my starting issue went away as well. We will see if it lasts. I find this really weird as neither of those parts have anything to do with how the car starts.
Old Mar 12, 2014 | 09:12 AM
snobordboy's Avatar
Moderator
Actually the temp sensors can cause issues. Do you have any Check Engine codes, or a Check Engine light on?
I ask since my car would have random issues, and I traced it to a temp sensor on the head. Problem was, my CEL was not working, so I had no idea. Only found it by plugging in another ecu so that the CEL worked.
Old Mar 12, 2014 | 09:40 AM
t5contra's Avatar
My CEL is on but its for an egr valve. I cleaned it twice and is still triggers it. We dont have smog or inspection here in Miami so I can live with it, at least for now. No other cel then that. I didnt really bother to look at sensor, I should have at least cleaned it but this was more of a parking lot repair then anything else. My thermostat was stuck.
Old Mar 12, 2014 | 11:45 PM
test the engine coolant temperature sensor for ohms across the pins ... should be 2000-2500 ohms when the car is completely cold and 180-250 ohms when the car is completely warmed up
it's the two pin sensor under the distributor
Hadi585
14
Mar 28, 2014 09:44 AM
Dead CIVIC
17
Mar 4, 2011 03:44 PM
DJaeMac
Oct 8, 2007 08:44 PM
AzntstyleZ
Nov 10, 2005 10:47 PM
integration
Dec 1, 2002 09:15 PM
