Double check that torque wrench!
Old Mar 10, 2014 | 05:16 PM
noob1971's Avatar
Default Double check that torque wrench!
When the timing belt is not tight enough, the motor in my 92 cx goes, 'clickety clack, clickety clack!!!'
Old Mar 10, 2014 | 11:46 PM
holmesnmanny's Avatar
Default Re: Double check that torque wrench!
You never apply any tension manually to any timing belt or balance shaft belt. Period.
They either have auto tensioners or they have manual tensioners that are spring loaded.
If you have any specific questions as to how to do either, just ask.
Old Mar 12, 2014 | 12:29 AM
slowcivic2k's Avatar
Not correct, many engines require a pre-load tension on a manual tensioner or automatic tensioner. GM's, Mitsubishi's, Cadillac's, etc all specify a preload tension prior to engaging the tensioner, either automatic, or manual.
Honda tells you to hold the crank bolt in a clock-wise direction while tightening the tensioner bolt. There must be no slack on the drive side of the belt, or else noise and reduced belt life will result, including possibly jumping time.
annette'shonda
Apr 8, 2013 12:39 PM
danewickenhauser
Jul 25, 2009 04:38 PM
drbenne
Nov 19, 2007 01:39 AM
tmrtwo
Feb 2, 2007 04:43 PM
skrewdlude
Oct 4, 2005 04:42 AM
