timing belt tension/ adjustment bolt help
Old Mar 9, 2014 | 06:42 AM
eg6_rugby's Avatar
Default timing belt tension/ adjustment bolt help
ive been banging my head on this issue for a few days now. b16a2 new timing belt is on but appears to be to tight to a point where my exhaust cam when lined perfect rises significantly. ive lined the crank up for TDC. Ive tried to loosen the tensioner bolt but damn thing wont budge. DO i need to release the spring first? any help on this will be awesome. this is the last thing i have to do to complete the motor.
belt fully on and cams lined
exhaust cam rising upward
Old Mar 9, 2014 | 08:38 AM
Former User's Avatar
Default Re: timing belt tension/ adjustment bolt help
Put a 14-mm socket on the tensioner adjusting bolt and loosen it by turning counterclockwise.
Old Mar 9, 2014 | 08:56 AM
tony_2018's Avatar
Fish Twig
You need to have the can caps back on before tightening. Think about it, you're putting tension on one side so theoretically the other side will rise.
Old Mar 9, 2014 | 08:57 AM
eg6_rugby's Avatar
thanks, yea i tried that and the damn thing will not move.
Old Mar 9, 2014 | 09:03 AM
eg6_rugby's Avatar
yea the only thing that stopped me from doing that was the fact that the exhaust cam was riding to high where i felt trying to put the cap back on would mess it up.
Old Mar 9, 2014 | 09:11 AM
apexi_rsx's Avatar
you tighten cam caps in sequence it will lower and ease it's self down
Old Mar 9, 2014 | 09:13 AM
eg6_rugby's Avatar
so it could be im just be over cautious about this. spent alot of money building the bottom end up and dont want to ruin all the hard work with a timing belt issue
eklum
Sep 29, 2007 12:27 PM
bOOsTiNSoHcVtEc
Aug 5, 2005 09:28 AM
BACKintheDA
Sep 19, 2004 03:26 PM
sleepin91teg
Jul 13, 2004 10:44 AM
Green94GSR
Mar 19, 2004 07:47 AM
