Help...
Old Jul 12, 2004 | 02:41 PM
sleepin91teg's Avatar
Default Help...
Got my b18a1 head back...new cams, springs, retainers...3 angle valve job, all that stuff...and also a .020" MILL on the head...so i torque it all down, and its beautiful, and rolls over nicely...but i have slack in my timing belt...i think its enough to jump gears...the tensioner is tight...so i have no clue what it is...i think its cuz i got the head milled .020" and im using stock cam gears...but i got AEM cam gears that come tomorow...help...
Old Jul 12, 2004 | 02:43 PM
Circuit Star-29's Avatar
Default Re: Help... (sleepin91teg)
You should be able to take out the slack with the belt tensioner.
Old Jul 12, 2004 | 03:03 PM
Default Re: Help... (nathan atwell)
Its just a bolt, in the timing cover...and i tightened it down...its snug, but not 4000ft lbs...i dont know what to do..
Old Jul 12, 2004 | 05:00 PM
There should be a sprung pulley that you can adjust to put more tension on the belt.
Old Jul 12, 2004 | 05:57 PM
Thanks guys...i got it...
Old Jul 12, 2004 | 08:06 PM
spoonek9's Avatar
Loosen tensioner bolt 180 degrees. Rotate crankshaft 3 teeth on the TIMING GEAR counterclockwise. Then retorque the tensioner bolt. This should be done after the timing belt has been set. To set the timing belt rotate crankshaft counterclockwise 5 or 6 revolutions.
Old Jul 13, 2004 | 03:40 AM
Default Re: Help... (spoonek9)
Yes i just read that in the HAYNES manual...Thanx...i got it one and tight!!!
Old Jul 13, 2004 | 10:44 AM
HE got it, YYeeehhhh, yeehhhhh. thread done.
giovannie23
Jul 20, 2013 11:52 PM
eracer08
Jun 1, 2013 07:23 AM
yeaBuddy
Jul 17, 2011 09:19 AM
bOOsTiNSoHcVtEc
Aug 5, 2005 09:28 AM
spooncivic1
Oct 4, 2004 06:03 PM
