water in tire well
Old Oct 29, 2002 | 11:48 AM
johnzm's Avatar
Default water in tire well
can u guys point out come common areas for water leaking in, and how u fixed it?
ive read something about the sunroof drain tubes, but i have no idea what to use to clean them out....
Old Oct 29, 2002 | 07:52 PM
johnzm's Avatar
Default Re: water in tire well (johnzm)
TTT come on guys i KNOW my car isint the only one that leaks!@
Old Oct 29, 2002 | 08:08 PM
kikujiro's Avatar
Never had to clean one out... but maybe a compressor with one of those air blower attachments might work. Just a thought anyway.
Old Oct 29, 2002 | 08:54 PM
cbrman's Avatar
well i have been unsuccessful locating my leak, but then again it isnt my first priority. The drain tubes are right behind the wheelwell, unless you want to remove the headliner compressed air isnt gonna do the trick. Pull the drain tubes out of the L shaped elbow that is in the body. there will be a black pointy end in the tube with a + shaped slit in it. I just yanked it out and stuck something in there and pulled the crap out. I suppose you could rinse it out or something as well. In my case there was crap in there, but that wasnt the cause.
I have also heard that the seal/gasket around the taillights will leak and allow water in the hatch area.
Also when you open the hatch, look up by the hatch hinges. If there are cracks near the hinges, or where the roof meets the inside of the hatch water can seep in these cracks as well. Get some clear silicon caulk/sealer and apply a light layer over the cracks to seal out water.
HTH
Steven
Old Oct 29, 2002 | 09:43 PM
MisterB's Avatar
Default Re: water in tire well (cbrman)
sounds to me that this is the problem many people went through the same thing just like me but im to lazy to silicone it and honda wants $20 a gasket
Old Oct 30, 2002 | 03:02 AM
SmokyMtnRex's Avatar
New User
Mine does it too. I think there is some kind of hole in my tire hub though.
Old Oct 30, 2002 | 05:00 AM
CRXSIFUEL's Avatar
Default Re: water in tire well (SmokyMtnRex)
yo its the hatch seal, i fixed my tail lights and bought a hatch seal, (70 bucks from honda,) by the tail in the corner of the hatch the seals become faulty over time just order a new seal from honda and u are all set
FUEL
Old Oct 30, 2002 | 09:11 AM
STK B16's Avatar
Default Re: water in tire well (CRXSIFUEL)
I boought new seals for my taillights when this happen and it fix the problem.. same thing with my brother's ef.. did the same thing and fixed the problem.. So i would say change the seal on the taillights
Old Oct 30, 2002 | 12:02 PM
cbrman's Avatar
Bro,
I wish that was the case. I have replaced all window seals, moonroof seals and the 70 dollar hatch seal. The hatch seal when new prevented the hatch squeek, but after the weight of the hatch compressed it a little the hatch squeek came back. That did not cure the leak in my case. I swear, one of these days i am gonna recaulk/reseal the tail lights and see if that is the problem
FUEL
ProStreetDriver
Detailing
Mar 18, 2017 10:12 PM
dleccord
Dec 23, 2009 06:40 PM
som3on3_10
Jan 6, 2008 07:25 PM
sloz64now
Dec 1, 2004 05:46 PM
OgunplayGSR
Jul 12, 2002 10:12 PM
